MHB Sum or difference formula (sin, cos, and tan)
To find the sine, cosine, and tangent of the angle ${-13\pi}/{12}$, the first step is to add $2\pi$, resulting in $\frac{11}{12}\pi$. This angle can be expressed as a sum of known angles, such as $\frac{3\pi}{4} + \frac{\pi}{6}$ or $\frac{1}{2}\pi + \frac{1}{4}\pi + \frac{1}{6}\pi. By using the angle-sum formulas, the exact values for sine, cosine, and tangent can be calculated. The discussion emphasizes the importance of expressing angles in a manageable form before applying trigonometric identities. Understanding these formulas simplifies the process of finding trigonometric values for complex angles.
Taryn1
So I'm supposed to find the exact values of the sine, cosine, and tangent of an angle by using a sum or difference formula ( i.e. sin(x+y)=sin(x)cos(y)+cos(x)sin(y) ), but this is the angle I was given: ${-13\pi}/{12}$. How do I use a sum or difference formula to get the sin, cos, and tan of that?
Mathematics news on Phys.org
I would first add $2\pi$ to get:
$$-\frac{13}{12}\pi+2\pi=\frac{11}{12}\pi$$
And then write:
$$\frac{11}{12}\pi=\frac{1}{2}\pi+\frac{1}{4}\pi+\frac{1}{6}\pi$$
Now you can use the angle-sum formulas. :)
And then write:
Or even just $\displaystyle \begin{align*} \frac{3\pi}{4} + \frac{\pi}{6} \end{align*}$ or $\displaystyle \begin{align*} \frac{\pi}{4} + \frac{2\pi}{3} \end{align*}$ to avoid multiple uses of the compound angle formulae...
Thanks for your help! That makes more sense now.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
