Sum to infinity of Heaviside function
In summary, the Fourier series of the square wave is calculated to be: Complex coefficients = 1 - H(t-2pi)
joriarty
62
I'm revising my course text for my exam and came across a Fourier series problem finding the Fourier series of the square wave:
[PLAIN]http://img574.imageshack.us/img574/5862/eq1.png.
It is then calculated that the complex Fourier coefficients are
[PLAIN]http://img232.imageshack.us/img232/5863/eq2.png
with no intermediary calculations provided.
What I don't understand is how they got:
[PLAIN]http://img2.imageshack.us/img2/1776/eq3y.png
Could someone please explain? Thanks :)
Take a look at the integration range and then at the definition of f again. Then you should see it. Drawing f could also help.
I'm still not getting it. Plotting f(t) I get a series of step functions as expected where f(t) = 1 from t = 0 to pi (ie where n = 0), zero from pi to 2*pi (ie where n = 1), one from 2*pi to 3*pi (n = 2) and so on.
But I don't see how this infinite series can be equated to 1 - H(t - pi) which is just equal to 1 from t = 0 to pi and zero elsewhere. That's equivalent to f(t) summed from n = 0 to 0.
U do Fourier transform for periodic functions. F is periodic with period 2Pi. So in the integration range f is just 1-H...
If you are integrating from 0 to 2pi, you don't care what happens from 2*pi to 3*pi and so on.
They don't appear to be claiming anything about the entire series, just about it's behavior on [tex][0,2\pi][/tex].
Ah, I get it now. Thanks guys
FAQ: Sum to infinity of Heaviside function
1. What is the sum to infinity of the Heaviside function?
The sum to infinity of the Heaviside function is equal to 1. This is because the Heaviside function is a step function that is defined as 0 for negative values and 1 for positive values. As the function approaches infinity, it remains at 1, resulting in the sum to infinity being equal to 1.
2. What is the purpose of the Heaviside function?
The Heaviside function is commonly used in mathematics and physics to define a step change or discontinuity in a function. It is also used to simplify mathematical expressions and to represent certain physical phenomena, such as the activation of a switch or the opening of a gate.
3. How is the Heaviside function related to the Dirac delta function?
The Heaviside function is the integral of the Dirac delta function. This means that the Heaviside function is equal to 0 for negative values and 1 for positive values, while the Dirac delta function is infinite at 0 and 0 everywhere else. They are intimately related and are often used together in mathematical and scientific applications.
4. Can the Heaviside function be extended to complex numbers?
Yes, the Heaviside function can be extended to complex numbers. In the complex plane, the Heaviside function is defined as 0 for values with a negative real part and 1 for values with a positive real part. This extension is useful in applications such as signal processing and control theory.
5. How is the Heaviside function used in Laplace transforms?
The Heaviside function is often used in Laplace transforms to represent a unit step function. It is used to simplify the integration of certain functions and to model physical systems with sudden changes. The Laplace transform of the Heaviside function is equal to 1/s, where s is the complex frequency variable.
