Summation formula for trig functions
In summary, the conversation discusses the possibility of finding a summation formula for the sum of an expression with n as an argument in a trigonometric function, similar to how an integral is defined as a Riemann sum of an infinite number of points. It is mentioned that there are some tricks that can be used, but not every series can be summed explicitly. The conversation also suggests using complex variables and the ln(1+z) series to find a summation formula for specific series, such as the periodic ramp function. It is suggested to try using this method for a square wave to better understand how it works.
FrankJ777
140
Does anyone know if there is a summation formula to find the sum of an expression with n as an argument in a trig function? I'm asking this because I'm learning about Fourier series/analysis but it seems that once we have the Fourier series we only sum for n=1,n=2,n=3... We never sum there series all the way to infinity. Is there a way to do that, simular to the way an integral is defiened as the Riemann sum of an infinate number of points?
If anyone can point me in a good dirrection I would sincerely appreciate it.
Thanks a lot
Mathematics news on Phys.org
There are some tricks that can be used, but not every series can be summed explicitly. As an example, take
[tex]\sum \frac1n \sin nx[/tex]
Using complex variables, we can write this as
[tex]\Im \sum \frac1n e^{inx}[/tex]
Now let [itex]z = e^{ix}[/itex], so we can write
[tex]\Im \sum \frac1n z^n[/tex]
And now use the series for [itex]\ln (1+z)[/itex]:
[tex]\ln (1+z) = z - \frac{z^2}2 + \frac{z^3}3 - \frac{z^4}4 + \ldots[/tex]
to write the sum as
[tex]\Im (- \ln (1-z)) = - \arg (1-z) = - \arctan \frac{\Im (1-z)}{\Re (1-z)}[/tex]
Finally, put in the definition of z:
[tex]\sum \frac1n \sin nx = \arctan \frac{\sin x}{1 - \cos x}[/tex]
If you plot this, it reproduces the periodic ramp function represented by the original series.
To learn how it works, why don't you try working it out for a square wave? Basically all you do is use the ln(1+z) series in creative ways.
Related to Summation formula for trig functions
1. What is the summation formula for trig functions?
The summation formula for trig functions is a mathematical expression used to find the sum of a series of trigonometric functions, such as sine and cosine. It is also known as the trigonometric addition formula.
2. How is the summation formula for trig functions derived?
The summation formula for trig functions is derived from the trigonometric identities and the properties of series. It involves using the identities to manipulate the series and then using the properties of series to simplify it into a single expression.
3. What is the purpose of the summation formula for trig functions?
The purpose of the summation formula for trig functions is to simplify calculations involving the sum of multiple trigonometric functions. It is especially useful in fields such as mathematics, physics, and engineering where trigonometry is often used in calculations.
4. Can the summation formula for trig functions be applied to any trigonometric function?
Yes, the summation formula for trig functions can be applied to any trigonometric function, including sine, cosine, tangent, cotangent, secant, and cosecant. However, the formula may look slightly different for each function.
5. Are there any alternative methods to finding the sum of trigonometric functions?
Yes, there are alternative methods, such as using the product-to-sum or sum-to-product identities, to find the sum of trigonometric functions. These methods may be more efficient for certain types of problems and should be used depending on the specific situation.
