MHB Summation: trigonometric identity
The discussion centers around proving the trigonometric identity involving a summation of cosine terms divided by powers of cosine. Participants suggest using mathematical induction to approach the proof, recommending separate treatment for even and odd cases of n. The original poster clarifies that the question is intended as a challenge rather than a request for assistance. The conversation emphasizes the complexity of the identity and the need for careful consideration in the proof process. Overall, the thread highlights the intricacies of trigonometric identities and the methods used to prove them.
hxthanh
Prove that:
$\displaystyle\sum_{k=0}^n \frac{\cos(k x)}{\cos^kx} = \frac{1+(-1)^n}{2\cos^nx} + \dfrac{2\sin\big(\lfloor\frac{n+1}{2}\rfloor x\big) \cos\big(\lfloor\frac{n+2}{2}\rfloor x\big)} {\sin x\cos^n x} \qquad\qquad (\frac{2x}{\pi}\not\in \mathbb Z)$
*note: $\lfloor x\rfloor$ is floor function of $x$
Mathematics news on Phys.org
Re: Summation trigonometry identity
hxthanh said:
Prove that:
Have you tried proving this by induction? Hint: you may find it easier to treat the cases $n$ even and $n$ odd separately.
I have learned from the OP that this question is meant as a challenge rather than seeking help, so it has been moved accordingly.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
