- #36
Garth
- 107
I think you are following a false trail here.RandallB said:Is this the key to figuring out the additional time dilation angle to be added to the GR curve in space (only 1/2 the needed angle)? Similar to the 900 Doppler effect of red shift ( I don’t recall - what’s the correct term for this?) when a high speed light emitting source passes at it’s closest point to an observer.
While object (light) follows the curve space path of GR as it descends deeper into the gravity well and experiences a Blue Shift . Can we use that apparent increase in energy as an “apparent increase” in mass (that goes away as it departs the sun) to calculate an additional displacement for the higher mass to account for the angular change caused by the time dilation?
The photon travels along a straight line - a geodesic - and as it is light traveling at the speed of light that geodesic is a null-geodesic because the photons's proper time along its path is zero.
That straight line appears 'curved', that is it is deflected, because the space-time hyper-surface along which it is traveling is curved by the presence of the Sun's mass and this curvature is that which gives the Sun its gravitational field.
The photon has no rest mass, the change of its energy does not alter its path as all objects or photons fall at the same rate in GR, whatever their mass or energy - that is the essence of the Equivalence Principle and verified in experiments by Galileo onwards. (Cannon balls and feathers fall at the same rate in a vacuum.)
In order to calculate the amount of deflection you have to solve the equation of motion of the photon across the curved space-time surface, it is an involved calculation that however may be broken down into two components.
One component is due to the photon 'falling' towards the Sun, which is half the total, and this can be identified with the effect of time dilation at a series of momentarily stationary frames of reference along the path through which the light ray passes. The other half component is due to the curvature of space on its own.
I hope this helps.
Garth
