Sunlight absorption spectrum and colors in sunlight
In summary, the conversation discusses the concept of whether sunlight contains all wavelengths and colors in the visible spectrum. It is explained that while the sun emits a continuous spectrum of light, certain wavelengths are absorbed by substances in the sun's atmosphere, resulting in black lines on the absorption spectrum. It is noted that the absorption lines do not completely remove these wavelengths, but rather there is just less of them than expected. The conversation also touches on the technical difference between wavelengths and colors and mentions some notable absorption lines in the solar spectrum.
Karagoz
Hi.
In physics articles, they say that sun light is white, and contain all colors.
But they show say that the Sun's atmosphere absorb light at certain wavelengths, causing the intensity of the light at this wavelength to drop and appear dark.
And the absorption spectrum looks like this:
Does those black lines on the sun light spectrum show that the sunlight that reach the Earth doesn't contain all colors?
Science news on Phys.org
Can you describe your understanding of what is the difference between 'all wavelengths' and 'all colours'?
But if all visible wavelengths are not contained in sunlight, doesn't it mean also that all colors are not contained in that sunlight?
You haven't answered my question. I'm not trying to be clever here, nor mean - I'm just asking you to try and define what it means to see all colours. What it means to perceive light as white?
Is 650 nm a colour? Is a combination of two discrete wavelengths a colour?
I'll assume here that OP is asking whether sunlight contains all wavelengths in the visible spectrum (realizing there is a technical difference between wavelengths and colors). The black lines are indeed wavelengths that are missing from the solar spectrum. Substances in the sun are absorbing those wavelengths from the continuous spectrum of light generated in the sun.
Likes sophiecentaur
There are not, though (in general). Absorption lines do not mean that that wavelength was entirely removed - there's just less of it than we'd normally expect.
Likes sophiecentaur and Charles Link
The atomic absorption lines are narrow enough in ## \Delta \lambda ## that they do not block what could be considered an entire color. The wavelength of 650 nm (that might be blocked) is essentially the same color as the wavelengths 651-655 nm. The question the OP is asking is really splitting hairs. In making the statement "sunlight contains all the colors of the visible spectrum", I don't think any qualifying statements or disclaimers need to be included. And even at these absorption wavelengths, there is still some light at those wavelengths. It is simply dimmer than the adjacent wavelengths. ## \\ ## And just an item of interest: What are two very prominent absorption lines in the spectrum right at ## \lambda =589.0\, nm ## and ## \lambda =589.6 \, nm ## are no doubt the Na =sodium absorption lines. A sodium arc lamp radiates very strongly at these wavelengths. A couple of the other absorption lines would be due to electronic transitions in the hydrogen atom. These include ## \lambda=410.1, 434.0, 486.1, ## and ## 656.2 \, nm ##. Some additional googling gives the results that these are known as the Fraunhofer absorption lines in the solar spectrum, and a complete table of these lines with the associated atom was found in one article.
Likes sophiecentaur
Right, and the form of the absorption line depends on the resolution of the recording instrument. So even if all of a particular wavelength were removed, it might not appear that way in the recording as light from nearby wavelengths will encroach.
Related to Sunlight absorption spectrum and colors in sunlight
1. What is the sunlight absorption spectrum?
The sunlight absorption spectrum refers to the range of wavelengths of electromagnetic radiation that are absorbed by the Earth's atmosphere when sunlight passes through it.
2. Why are certain colors present in sunlight?
The colors present in sunlight are a result of the visible light spectrum, which is made up of all the colors of the rainbow. When sunlight passes through the atmosphere, it is scattered and reflected, allowing us to see the different colors.
3. How does the atmosphere affect the absorption of sunlight?
The Earth's atmosphere is made up of various gases and particles that can absorb and scatter sunlight. This process can affect the intensity and distribution of different colors in sunlight, leading to variations in the absorption spectrum.
4. What is the role of the ozone layer in sunlight absorption?
The ozone layer is a protective layer in the Earth's atmosphere that absorbs harmful ultraviolet (UV) radiation from the sun. Its presence plays a crucial role in regulating the amount of UV radiation that reaches the Earth's surface and affects the absorption spectrum of sunlight.
5. How does the angle of sunlight affect its absorption?
The angle at which sunlight hits the Earth's atmosphere can affect the amount of absorption that occurs. For example, when sunlight hits the atmosphere at a lower angle, it has to pass through a thicker layer of air, leading to more absorption of certain colors and a change in the overall absorption spectrum.
  • Electromagnetism
  • Astronomy and Astrophysics
