Sun's Shrinkage due to Gravity: Visualize the Impact
In summary: The ray would be moving in a direction perpendicular to the observer-sun line , and would be bent by the gravitational field of the sun.
B0b-A
155
32
How much smaller does the sun appear because of it's gravitational field ?
This illustration shows EM waves being bent by the gravitational well of the sun.
The light from the sun itself will also be bent by its gravitational well, making the sun appear smaller , ( and have barrel distortion ).
So how much smaller does the sun's disc appear, compared with it's true diameter ?.
[ Next question: what will be the shrinkage with giant stars whose mass is 1000x suns ? ].
Why smaller?
A.T. said:
Why smaller?
I thought the rays from the perimeter of the sun would be bent by gravity toward the observer-sun axis , making the sun look smaller when viewed from Earth* , [ * not an atmospheric effect , for the purposes of this question assume Earth has no atmosphere ].
B0b-A said:
I thought the rays from the perimeter of the sun would be bent toward the observer-sun axis, making the sun look smaller when viewed from Earth
Why would that make the Sun look smaller?
by your repetition are you subtly hinting that I've got the wrong end of the stick and the sun appears larger because of gravitational lensing ?.
Hmm, it just occurred to me that the edges of the far hemisphere of the sun would become visible from Earth because of the gravitational distortion : that would make the sun appear bigger.
The visual size depends on the angle at which the most outer rays arrive at the eye, not on which parts of the object send these rays. In general these two things are independent, but in this case they happen to coincide: you see the sun bigger and more parts of it.
What would be the effect on something really massive like a galaxy ? :
would it just appear uniformly magnified ?, or with radial distortion, ( see attached) ...
Light coming out of the Sun is moving [em]radially[/em] with respect to the Sun, so it won't be bent, only "slowed" so to say. To be bent its direction vector has to have tangential component.
Edit: by "slowed" I mean gravitational redshift, of course.
This is incorrect. Draw yourself a picture of a ray coming from the edge of the sun to an observer on Earth. It is certainly not moving radially.
FAQ: Sun's Shrinkage due to Gravity: Visualize the Impact
How does gravity cause the Sun to shrink?
Gravity causes the Sun to shrink by pulling the outer layers of the Sun towards its center. As these layers move towards the center, they become more compressed, resulting in a decrease in the Sun's size.
Will the Sun continue to shrink forever?
No, the Sun will eventually reach a stable size once the forces of gravity and the internal pressure of the Sun reach equilibrium. This is known as the main sequence stage, which the Sun is currently in.
How does the shrinking of the Sun affect its temperature?
As the Sun shrinks, the particles within it become more compressed, causing an increase in temperature. This is due to the conservation of energy, where the potential energy of the particles is converted into thermal energy.
What other factors can affect the Sun's size?
Aside from gravity, the Sun's size can also be influenced by its internal nuclear reactions and the amount of mass it has. Changes in these factors can cause the Sun to expand or contract over time.
Is the Sun's shrinking visible to the naked eye?
No, the Sun's shrinking due to gravity is not visible to the naked eye. The changes in the Sun's size are very small and can only be measured using specialized instruments and techniques.
