Superconducting induction coil
In summary, when an alternating flux is applied to a superconducting coil, an emf is initially produced to generate a current in the coil. However, due to the low mass of conduction electrons, the current will persist indefinitely after the flux has stopped varying. This is different from non-superconducting coils where a nonzero emf is necessary to maintain the current. Special coatings have been developed to minimize eddy currents induced during ramp-up of magnetic fields in magnets with superconducting coils.
vin300
603
Looked at Maxwell's eqns after quite some time,and was wondering, what happens if we apply an alternating flux to a superconducting coil? An emf should be produced, but there's actually no emf in a superconductor!
Well, a superconducting coil behaves more or less just like an ideal lossless coil. If the coil is part of a closed circuit you will induce a current.
Although -depending on the exact layout= flux quantization might also be important which course wouldn't be the case for a normal circuit.
double post...
See Meissner Effect in
http://en.wikipedia.org/wiki/Meissner_effect
Read about Type I and Type II superconductors in
http://hyperphysics.phy-astr.gsu.edu/hbase/solids/meis.html
and
http://www.superconductors.org/
During ramp-up of magnetic fields in magnets with superconducting coils, eddy currents induced by the emf within the multi-wire superconducting cable (often carrying over 10,000 amps) is a serious problem, and special coatings on the individual wires have been developed to minimize them.
Bob S
Actually, there is. It's what engenders the current in the coil. Note, however, that it is not what maintains the current, once the current has been established. A nonzero emf is necessary to maintain an established current (against ohmic resistance) only in the case of non-superconducting coils. Owing to the low mass of conduction electrons, only a very brief time-varying flux is normally required to engender large currents in superconducting coils. And in the case of a superconducting coil, these currents will persist indefinitely after the flux has stopped varying in time. One of my favorite demonstrations is where a superconducting washer is dropped down on a bar magnet. Current is engendered in the washer as the magnetic flux through it varies in time. The direction of the current is such that its own magnetic field opposes the external field that set it up (Lenz's Law). Once the current has become great enough, the washer stops descending and "floats" indefinitely, part way down the bar magnet, seemingly defying gravity.
FAQ: Superconducting induction coil
What is a superconducting induction coil?
A superconducting induction coil is a device made of a superconducting material that is used to generate a strong magnetic field. It consists of a wire or coil made of a superconducting material, such as niobium-titanium, that is cooled to very low temperatures to allow for the flow of electric current without resistance.
How does a superconducting induction coil work?
A superconducting induction coil works by conducting an electric current through a superconducting material, which generates a strong magnetic field. The superconducting material has zero electrical resistance when it is cooled to very low temperatures, allowing for the continuous flow of current and the creation of a strong magnetic field.
What are the advantages of using a superconducting induction coil?
The use of a superconducting induction coil has several advantages. These include high magnetic field strength, high energy efficiency, and low operating costs due to the absence of electrical resistance. Superconducting induction coils also have a fast response time and can generate strong magnetic fields without the need for bulky equipment.
What are the potential applications of a superconducting induction coil?
A superconducting induction coil has a wide range of potential applications in various fields such as medical imaging, particle accelerators, nuclear magnetic resonance (NMR) spectroscopy, and magnetic levitation trains. They are also used in research labs for experiments that require strong magnetic fields.
What are the challenges of using a superconducting induction coil?
One of the main challenges of using a superconducting induction coil is the need for extremely low temperatures for the superconducting material to work effectively. This requires expensive cooling equipment and can limit the portability of the device. Superconducting materials are also quite delicate and can be easily damaged, requiring careful handling and maintenance.
