Superconductivity and Fermi levels
In summary: They are different types of materials. In summary, the Fermi function states that as the temperature of a semiconductor increases, the likelihood of electrons jumping to the conduction band also increases. However, in superconductors, where the temperature is extremely low, the Fermi level, band gap theory, and superconductivity are still related. This is because under the superconducting transition temperature, paired electrons are de-paired and move to the single electron state, increasing the single electron distribution. Superconductivity is not a band structure phenomenon, but rather a result of a net positive attraction between electrons causing a gapped ground state. This gap allows for electrons to condense into pairs and travel through the solid without scattering, due to quantum coherence.
SockCymbal
So, according to the Fermi function, the higher the temperature of a semiconductor, the higher the likelihood that the electrons can jump to the conduction band. But in superconductors, obviously the temperature is extremely low, so how does the Fermi level, band gap theory, and superconductivity relate?
The single electron are located above the energy gap, and the paired electrons (superconducting electrons) are located below the gap.
Under the superconducting transition temperature, the paired electrons will be de-paired with the temperature increasing. That means more superconducting electrons under the gap will be generated into the single electron state which is above the gap.
With the temperature increasing, the single electron distribution is obviously increasing, also.
Superconductivity is not a bandstructure phenomenon. The principle is entirely different. Namely, a net positive attraction between electrons causes a gapped ground state to form. This has been proven to be generally true, and in the case of conventional superconductors, phonons mediate this attraction. This energy gap results in electrons condensing into pairs. Excitaions within the solid are not sufficient to overcome this gap and so these paired electrons are able to travel through the solid without interacting (scattering) off anything else present in the solid. Technically, it is not so much that this gap is so massive that it dwarfs all the would be excitations. Instead it is the quantum coherence of the superconducting pairs that keeps them from scattering. ie: if you want to scatter one pair then you would have to scatter all of them.
BANG!
Usually, superconductors aren't semi-conductors but metals.
Related to Superconductivity and Fermi levels
What is superconductivity?
Superconductivity is a phenomenon in which certain materials exhibit zero electrical resistance and expel magnetic fields at very low temperatures. This allows for the transmission of electricity with virtually no energy loss.
How does superconductivity occur?
Superconductivity occurs when electrons in a material form pairs and move through the material without resistance. This is due to the alignment of the electrons' spin and orbital momentum, which allows them to move without colliding with other particles.
What is the significance of the Fermi level in superconductivity?
The Fermi level is the energy level at which electrons in a material have a 50% chance of being occupied. In superconductors, the Fermi level plays a crucial role in determining the strength of electron pairing and the critical temperature at which superconductivity occurs.
What are the applications of superconductivity?
Superconductivity has many practical applications, such as in medical imaging (MRI machines), high-speed trains (Maglev trains), and particle accelerators. It also has the potential to revolutionize energy transmission and storage, as well as computing technology.
What are the challenges in achieving superconductivity at higher temperatures?
Currently, superconductivity is only observed at extremely low temperatures, which limits its practical applications. Scientists are still working to understand the mechanisms of superconductivity and find materials that exhibit it at higher temperatures. One major challenge is preventing the material from breaking down under the high magnetic fields required for superconductivity.
