Superconductor in a hollow cylinder -- two different end states. Why?
In summary, when a magnetic field is applied to a superconductor during cool down, the field gets trapped in the hole of the hollow cylinder. In the superconducting state, the magnetic flux through the loop cannot change, resulting in the field being expelled to the exterior of the cylinder. This is due to the critical field strength and the inability to make the magnetic field arbitrarily strong without breaking down the superconductivity. This explanation applies mainly to type I superconductors, as small flux packets can enter the superconductor.
annaphys
69
When a magnetic field is applied to a SC during cool down, the field goes through the hole of the hollow cylinder. When the cool down first takes place and then later a magnetic field is applied, the magnetic field does not go through the hole of the hollow cylinder but rather is expelled to the exterior of the cylinder. Why does this happen? Why is there a difference between the two?
Inside the bulk of the superconductor, there can't be a magnetic field. So the field inside the hole get's trapped.
You can also show that the field can't have arbitrary values but gets quantized.
Hi thanks for the comment. What do you mean it gets trapped and which state are you referring to?
In the superconducting state, the magnetic flux through the loop cannot change. If there was a flux inside, before cooling down, it gets trapped, i.e. you can't change it any more when the loop has become superconducting.
Likes Vanadium 50
Ok that makes sense. And for the other case, i.e. when first cool down then magnetic field, what makes it that no flux goes through the hole? Is this simply because the hole is relatively small and the screening current on all sides pushes the magnetic field out of the hole? If we had a cylinder, with a meter wide hole, could we see flux going through it?
Yes, this is principally the explanation. The magnetic field cannot be made arbitrary strong, as this will make superconductivity to break down (critical field stength). The reasoning is also not completely applicable to type II superconductors, as small flux packets can enter the superconductor (Superconductivity vanishes at the location of the flux lines).
This is the key to the asymmetry. Whatever the flux was before the transition is what you have after. If it was zero before, it';s zero after. If it was non-zero before, it's non-zero after.
FAQ: Superconductor in a hollow cylinder -- two different end states. Why?
What is a superconductor?
A superconductor is a material that can conduct electricity with zero resistance when cooled below a certain temperature, called the critical temperature. This allows for the flow of electricity without any energy loss, making superconductors highly efficient for a variety of applications.
What is a hollow cylinder?
A hollow cylinder is a three-dimensional object with a circular cross-section and empty space inside. It is often used in engineering and physics as a structural element or as a container for fluids or gases.
What are the two different end states of a superconductor in a hollow cylinder?
The two different end states refer to the two possible ways a superconductor can behave in a hollow cylinder: as a type I or type II superconductor. In a type I superconductor, the magnetic field is completely expelled from the material when it becomes superconducting. In a type II superconductor, the magnetic field can penetrate the material in the form of quantized flux tubes.
Why are the two different end states of a superconductor in a hollow cylinder important?
The two different end states have different implications for the behavior and applications of superconductors. For example, type I superconductors are more suitable for applications that require strong magnetic fields, while type II superconductors are better for applications that require both strong magnetic fields and high critical currents.
What are some potential applications of superconductors in a hollow cylinder?
Superconductors in hollow cylinders have potential applications in a variety of fields, such as energy storage, magnetic levitation, and medical imaging. They can also be used in high-speed transportation systems, such as maglev trains, and in sensitive scientific instruments, such as particle accelerators.
