Superconductors and Fermi surfaces
In summary, the dispersion of Bogolyubov quasiparticles in a d-wave superconductor can be described by E(k) = ±√(ε(k)^2+Δ(k)^2). The Fermi surface of the normal state, defined by a discontinuity in the electron occupation number in momentum space, is not the same as the Fermi surface of the superconductor. In the BCS state, the original Fermi surface is smeared on the energy scale of Δ, but there is a surface of minimum gap in momentum space that is sometimes referred to as the "Fermi surface."
Niles
1,866
Hi
The dispersion of Bogolyubov quasiparticles in a d-wave superconductor is
[tex]
E(\mathbf k) = \pm \sqrt{\varepsilon (\mathbf k)^2+\Delta (\mathbf k)^2},
[/tex]
where ε(k) is the normal-state dispersion and ∆(k) is the gap dispersion. My question is: The Fermi surface (FS) of the normal state is just ε(k). Is this also the FS of the superconductor?
Superconducting states (i.e. BCS) are not Fermi balls, and so don't have Fermi surfaces.
Thanks for replying. I don't quite understand; at low temperatures, the electrons at the FS become unstable, and join in Cooper pairs to reduce energy. Then how can the BCS state not have a FS?
Again, thanks. I really appreciate it.
Hi Niles,
The Fermi surface in an interacting system may be defined in terms of a discontinuity in the electron occupation number [tex] n_k [/tex] in momentum space. For free electrons this discontinuity is one while for interacting electrons in a Fermi liquid this discontinuity is less than one. In an s-wave superconductor there is no longer this discontinuity because the qausiparticle energies no longer touch zero i.e. [tex] E_k = \epsilon_k - \mu [/tex] is replaced by [tex] E_k = \pm \sqrt{(\epsilon_k - \mu)^2 + \Delta^2} [/tex]. The original Fermi surface is smeared on the energy scale of [tex] \Delta [/tex]. However, sometimes people refer to the surface of minimum gap in momentum space as the "Fermi surface," and this surface tracks the original Fermi surface in many cases, but they are strictly speaking different concepts.
Hope this helps.
Related to Superconductors and Fermi surfaces
1. What is a superconductor?
A superconductor is a material that can conduct electricity with zero resistance when cooled below a certain critical temperature. This means that electrical current can flow through the material without any loss of energy, making superconductors extremely efficient conductors of electricity.
2. What is a Fermi surface?
A Fermi surface is a theoretical concept in solid-state physics that describes the boundary between filled and unfilled energy states of electrons in a solid material. It is a 3-dimensional representation of the energy levels of electrons in a material, and it helps to understand the electrical and thermal properties of materials.
3. How do superconductors and Fermi surfaces relate?
Fermi surfaces play a crucial role in the formation of superconductivity. In a superconductor, the Fermi surfaces of the electrons become perfectly matched, allowing them to form pairs and move through the material without any resistance. This pairing is what enables superconductors to conduct electricity with zero resistance.
4. What are the practical applications of superconductors and Fermi surfaces?
The most well-known application of superconductors is in MRI machines, where they are used to generate strong magnetic fields with minimal energy loss. Superconductors also have potential applications in power transmission, levitating trains, and quantum computing. Fermi surfaces are important in understanding the electronic properties of materials, which is crucial for developing new technologies such as semiconductors and solar cells.
5. Are there any challenges in working with superconductors and Fermi surfaces?
Yes, there are several challenges in working with superconductors and Fermi surfaces. One of the main challenges is achieving and maintaining the low temperatures required for superconductivity to occur. Another challenge is finding materials that exhibit superconductivity at higher temperatures, as most superconductors currently only work at very low temperatures. Additionally, understanding and manipulating Fermi surfaces is a complex task that requires advanced theoretical and experimental techniques.
