Superficial degree of divergence for scalar theories
In summary: E]## would still correspond to the ##\phi^4## term in the lagrangian).In summary, the conversation discusses the derivation of the degree of divergence for Feynman diagrams, where the result is given by $$D = [g_E] - \sum_{n=3}^{\infty} V_n [g_n]$$ In this equation, ##[g_E]## represents the dimension of the coefficient of the term with a certain number of external lines, and the sum is over all the vertices in the diagram. The conversation also touches upon the terminology of "summing over all possible scalar theories" and clarifies that it
CAF123
88
I have a few questions regarding the derivation of the degree of divergence for feynman diagrams. The result is $$D = [g_E] - \sum_{n=3}^{\infty} V_n [g_n]$$ (following notation in Srednicki, ##P118##)
I am trying to understand what ##[g_E]## is here? Since in this set up we are summing over all possible scalar theories ##n \in [3, \infty)##, we will have a tree level local interaction diagram corresponding to the case where ##E=i## where ##i## is some element of the set ##[3,\infty)##. So is it right to say that ##[g_E]## denotes a particular element of the set ##[3,\infty)##?
If that is correct, then in the theory $$\mathcal L = \frac{1}{2} Z_{\phi} \partial_{\mu} \phi \partial^{\mu} \phi - \frac{1}{2}Z_m m^2 \phi^2 - \frac{1}{k!} Z_g g \phi^k$$ (i.e a theory where we now include only one of the elements in the above set) the formula for ##D## now becomes ##D = [g_E] - v_k [g]## and in this case ##[g_E] = [g]##, with ##v_k## the number of times a vertex shows up in some diagram? Is that correct understanding?
Hi,
Well, I would not say that we are "summing over all possible scalar theories", that's misleading. We are consider one diagram in a single theory. Now, this diagram has a certain number of external lines, let's call it "k", and ##[g_E]## is the dimension of the coefficient of the term with k powers of the scalar field in the potential. For example, if there are 7 external lines, ##[g_E]## is the dimension of the coefficient of ##\phi^7##. Then the sum is over all the vertices in the diagram.
Hi nqred,
Srednicki begins by writing down $$\mathcal L = - \frac{1}{2} Z_{\phi} \partial_{\mu} \phi \partial^{\mu} \phi - \frac{1}{2}Z_m m^2 \phi^2 - \sum_{n=3}^{\infty} \frac{1}{n!} Z_n g_n \phi^n$$ which seems to me to be a summation over all possible scalar theories, i.e in such a theory we have a ##\phi^3, \phi^4...## etc interaction. Is it not? Suppose we have a diagram with E external legs. Then in ##D = [g_E] - \sum_{n=3}^{\infty} V_n [g_n]##, the first term ##[g_E]## corresponds to the tree level local interaction vertex that occurs when ##E=i## for some i in the interval [3,infinity]. So we can write $$D = [g_E] - V_i[g_i] - \sum_{n \neq i}^{\infty} V_n [g_n] = (1-V_i)[g_E] - \sum_{n \neq i}^{\infty} V_n [g_n]$$ Each of the ##[g_n]## have a different mass dimensionality in a fixed number of space time dimensions.
Am I thinking about this wrongly? Edit: The last equality I wrote must be wrong because it doesn't reproduce the correct D for some diagrams. I was thinking of the one loop box correction to the ##\phi^3## local vertex interaction. In d=6, the coupling has null mass dimension and we only have one theory (phi^3) so Srednicki's formula reduces to ##D = [g_E] - V_3 [g_3]##. In this case, ##V_3 = 4## and ##[g_E]## = 0. But this doesn't recover the D=-2 you get by power counting.
Thanks!
CAF123 said:
Hi nqred,
Hi again!
Well, it is just a question of terminology. The way I see it is that we are considering one theory (because we are dealing with a single lagrangian) but this theory may contain an infinite number of terms. Even if there is an infinite number of terms it is still one theory.
Yes, we can write this.
Not necessarily! One can also have ##\phi^4,\phi^5 \ldots ## terms! The theory will be nonrenormalizable but it is still perfectly well defined as an effective field theory
Thanks!
Watch out. This box diagram has four external lines. Therefore ##[g_E]## is the dimension of the coefficient of an ##\phi^4## interaction would have (note that it does not matter if there is such an interaction in the Lagrangian or not, ##[g_E]## is the dimension of the coefficient of such an interaction if it was present) and for a ##\phi^4## interaction in 6 dimensions, the coefficient would have dimension -2. So for your diagram, ##[g_E]=-2## and therefore D=-2.
Likes CAF123
Related to Superficial degree of divergence for scalar theories
1. What is the superficial degree of divergence for scalar theories?
The superficial degree of divergence for scalar theories is a measure of the number of divergent integrals that arise in a particular calculation. It is determined by the number of loops in the Feynman diagrams and the mass dimension of the fields involved.
2. Why is the superficial degree of divergence important in theoretical physics?
The superficial degree of divergence is important because it gives an indication of the level of difficulty in calculating physical quantities in a theory. A higher degree of divergence means more complicated calculations and potentially more infinities that need to be renormalized.
3. How is the superficial degree of divergence calculated?
The superficial degree of divergence is calculated by assigning a mass dimension to each field in the theory and counting the number of loops in the Feynman diagrams. The sum of these values gives the overall degree of divergence.
4. What is the relationship between the superficial degree of divergence and renormalizability?
The superficial degree of divergence is closely related to the renormalizability of a theory. A superficial degree of divergence of zero indicates that a theory is renormalizable, meaning that all infinities can be removed through a finite number of counterterms. A nonzero superficial degree of divergence indicates a non-renormalizable theory.
5. Can the superficial degree of divergence change in different calculations?
Yes, the superficial degree of divergence can vary depending on the specific physical quantity being calculated. For example, the superficial degree of divergence for a scattering process may be different from that of a decay process in the same theory. It is important to calculate the superficial degree of divergence for each individual calculation to properly assess the difficulty of the calculation and the renormalizability of the theory.
