Superheated Steam Turbine - on a question please
In summary: I know for this part I need to use the formula : S2 = Sf + x times Sfg - where x=dryness factor (but I don't know what Sf and Sfg are so I can solve for x so I need a pointer here please .For S2, you could use the equation: S2 = Sf + x*Sfg - where x is the dryness fraction.c) x is is dryness fraction so I have found this out in part (b) I believeYes, x is the dryness fraction.d) to find the work done I know that for an adiabatic process this is the change
Christy001
1. Superheated Steam enters a turbine with a pressure of 10 bar and a temp of 300 degrees celcius, and exits with a pressure of 0.046 bar. As the steam flows through the turbine it undergoes adiabatic expansion according to the law pv to the power 1.131 = constant
From Steam tables I have to calculate :
a) specific volume of steam at the turbine input and output (I assume that's just v straight from the Superheated tables at the relevant pressures ?)
b) Saturated vapour specific volume for the steam output pressure and state the steam condition ?
c) dryness fraction of the steam at the turbine exit ?
d) theoretical specific work output of the turbine ?
Can anyone help me on the above please as I've scoured the internet for a solution and got part of the way in understanding but then can't follow how the things are found on the steam tables and what equations are used - any help would be greatly appreciated
Since this is a homework question, you should have filled out the HW Template. Those are the Rules.
In order to receive help, you must also show some attempt at solving these questions.
For a) You have sufficient info for the inlet conditions to find spec. volume.
The same is not true for the exit, as seen by questions b), c), and d), where you must determine how the steam changes condition as it flows thru the turbine.
As stated in the problem, PVγ = Constant, where γ = 1.131
Here is more information on adiabatic processes:
http://en.wikipedia.org/wiki/Adiabatic_process
This should be enough information for you to work thru questions b), c), and d).
If you get stuck, repost to this thread with the details and we'll see if these blocks can't be overcome. :smile:
Hi - this is what I have worked out so far :
a) specific volume of steam at the turbine input and output :
At state 1 call the values S1, H1 and at state 2 call the values S2, H2,
From the Superheated steam tables I've looked up 300 degrees C and 1000 Kpa to give S1 (Sg) 7.125KJ/KG-K and H1 (Hg) = 3,052.15 KJ/KG
I know that as the process is Adiabatic then S1 = S2 therefore I think the answer to part (a) is 7.125 Kj/Kg-K for both answers.
(b) I know for this part I need to use the formula : S2 = Sf + x times Sfg - where x=dryness factor (but I don't know what Sf and Sfg are so I can solve for x so I need a pointer here please .
(c) x is is dryness fraction so I have found this out in part (b) I believe
(d) to find the work done I know that for an adiabatic process this is the change in H, so it's H2 - H1 - I know H1 from above. I know I need to use the formula :
H2= Hf + x times Hfg (at 0.046 bar) = I have worked out x - so do I just get Hf and Hfg from the Superheated Steam tables ?
thanks.
You want to reconsider the meaning of "adiabatic". The case ##\Delta S=0## is goes under the name "Isentropic".
The given expression for ##pv## should help you further to find the exit temperature.
S generally denotes the entropy of a substance, not specific volume, which is usually denoted by v. Also, the units of specific volume are m3/kg.
The steam tables also use g to denote the property in the vapor phase and f in the fluid phase; hence Sg is the entropy of the steam in the vapor phase.
You must pay attention to the units listed for each property.
You must correct your work on part a) first.
Not according to what you wrote in the previous section.
thanks.
If you've worked out the quality of the exhaust steam x, you haven't shared it with us yet.
The steam tables will list the enthalpy, entropy, and specific volume for the vapor and fluid phases of water/steam.
You know the exit pressure, and you know that the exit stream is a combination of liquid water and water vapor. What does that tell you about whether it is saturated or not? If it's saturated, what is the entropy of the saturated liquid, and what is the entropy of the saturated vapor? What is the temperature? What is the enthalpy of the saturated liquid and the saturated vapor. What is the enthalpy of the stream?
Chet
Chet
Hi. Thanks for the reply. This is where I get stuck as I can understand that when the steam enters at 450 it is superheated but at exit do I need to go back to the Saturated tables to obtain the temperature ?
By nature, superheated steam has a vapor quality of 100%, so yes, for the turbine exhaust, you'll have to go to the saturated vapor tables and use the vapor quality to calculate the properties of the exhaust steam.
http://en.wikipedia.org/wiki/Vapor_quality
Related to Superheated Steam Turbine - on a question please
1. What is a superheated steam turbine?
A superheated steam turbine is a type of turbine that uses superheated steam as its working fluid to convert thermal energy into mechanical energy. Superheated steam is steam that has been heated to a temperature above its boiling point at a given pressure, which increases its energy and efficiency as a working fluid.
2. How does a superheated steam turbine work?
A superheated steam turbine works by expanding high-pressure and high-temperature superheated steam through a series of stationary and rotating blades, which causes the steam to lose energy and increase its velocity. This high-speed steam then drives the turbine blades to produce mechanical energy, which can be used to power generators and other machinery.
3. What are the advantages of using a superheated steam turbine?
There are several advantages to using a superheated steam turbine. Firstly, superheated steam has a higher energy content compared to saturated steam, which means it can produce more mechanical energy. Additionally, superheated steam turbines have a higher efficiency and can operate at higher temperatures and pressures, making them ideal for industrial and power generation applications.
4. What are the potential drawbacks of a superheated steam turbine?
One potential drawback of a superheated steam turbine is the high initial cost of installation and maintenance. Superheated steam turbines also require a reliable source of high-pressure and high-temperature steam, which may not be available in all locations. Finally, the high temperatures and pressures involved in superheated steam turbines can pose safety hazards if not operated and maintained properly.
5. How is a superheated steam turbine different from other types of turbines?
A superheated steam turbine differs from other types of turbines in its use of superheated steam as the working fluid. Other types of turbines, such as gas turbines and steam turbines using saturated steam, have different operating principles and efficiencies. Additionally, superheated steam turbines are typically used in specific applications, such as power generation and industrial processes, while other turbines may be used for different purposes.
