- #36
yuiop
- 3,962
- 20
jonmtkisco said:On further thought, I believe the problem is that the Morgan calculator implements the standard FLRW interpretation of "space itself expanding" (which I'll refer to as the "expanding-space model") in a way which is incompatible with calculating parameters based on historical clock variance (which I'll refer to as the "clock-variance model.") That shouldn't be surprising. The expanding-space algorithm assumes that high-z photons have been sort of swimming upstream, into a visceral welling-up of intervening empty vacuum, for a very long time, in fact since a time when the presently observable universe was very much smaller than today.
If one starts with the assumption that newly-existing space does NOT viscerally well up between the photons' emission sources and their eventual target, slowing the photons' approach, then one must assume that all of the photons emitted at very early times from locations inside the bounds of our "presently observable universe" (e.g. CMB photons emitted at a distance of 42.2MLy from us) have passed us by long ago, and are no longer observable by us. We can be certain of this because, as I mentioned, photons emitted more recently and from much greater initial distances have already passed us by. At any given point in time, all photons must travel at the same speed.
This suggests an interpretation that the CMB photons we presently observe were emitted from a surface of last scattering which is more recent and much more distant than is predicted by the expanding-space model. In fact, it seems highly probable to me that they would have been emitted from an initial distance far beyond the present Particle Horizon calculated by the expanding-space model.
Clearly one mandatory requirement of the clock-variance model is that the higher the z-value of a photon, the greater the initial distance at which it was emitted. The is the opposite of the expanding-space model.
Jon
Hi Jon,
I just to clear up some definitions here (for my benefit so that I know we are talking about the same thing ;)
In the "space itself expanding" model there is no time dilation because galaxies are stationary with the "local space". That is pretty much the standard interpretaion in non mathematical descriptions of cosmology.
One alternative to the "space itself expanding" interpretation is galaxies moving through static space and that requires time dilation which I will call the SR model. In the SR model the radiation we see now as the CMB comes from a priordial "gas" moving at about 0.99c relative to us so the radiation was not emitted 300,000 years after the big bang but much later due to time dilation. One difficulty with the Sr interpretation is even the significant time dilation of the surface of last scattering is not enough to account for the significant delay in the light getting to us as well as getting the angular distance of fluctions in the CMB and the redshift/ luminosity predictions to the SR model to match up with actual observations. One possible fix to those problems may be to assume significant rapid inflation before the the time of last scattering which effectively gives the surface a head start. I hope someday, a better mathematician than me will try and work out the correlation of a SR+Initial Inflation model with observations. My hunch is that such a model will not require a cosmological constant and accelerating expansion. Such a model assumes static spacetime that is neither expanding or accelerating and that the speed of light and time itself is constant from the big bang until now if we ignore local gravitational variations and peculiar motions.
Your "clock-variance model" seems to based on the interpretaion that galaxies are essentially stationary and that the appaernet motion and redshift is due to clocks speeding up as the universe ages. In this model the speed of light is constant from the time of the big bang but the increasing clock rates make radar distances appear to be getting longer over time. Such a model requires local rulers and physical objects such as the Earth to be shrinking over time so that the speed of light appears constant over time locally. In this model some galaxy that was 13 billion light years away now was 13 billion light years away at the time of last scattering just after the big bang and it only theclock variance that causes us to percieve the galaxies as receding. Is that a correct interpretation of what you describe as the "clock-variance model"?
