B Superposed loads (gunpowder and bullets) igniting simultaneously in a barrel
  • B
  • Thread starter Thread starter manmade
    Pressure
The discussion explores the effects of firing two superposed loads of gunpowder and bullets in a barrel. It examines scenarios where the rear load fires first, potentially causing a barrel obstruction, and the implications of simultaneous firing on bullet velocity and pressure. The interaction between the two loads could lead to unpredictable outcomes, including the risk of barrel failure. The conversation suggests that using compressed coil springs instead of explosive charges could provide a more predictable analysis of the situation. Ultimately, the unpredictability and danger of such experiments are emphasized, advising against attempting them.
manmade
Look at this picture of two superposed loads:
Imagine that each bullet weight 150 grains and each gunpowder charge 50 grains.
If the rear load were to be fired first, it would be equal to firing two bullets +the weight of the front gunpowder charge. So a 350 grains bullet with a 50 grains gunpowder charge (if the front gunpowder charge would be compressed by the rear bullet, it might make the rear bullet slam into the front bullet which would then act as a barrel obstruction?).
But if both loads were to be fired simultaneously, will the pressure from the first load prevent the second bullet from escaping, or would it be equal to firing two bullets (300 grains) with one 100 grains gunpowder charge?
manmade said:
But if both loads were to be fired simultaneously, ...
The first ball would travel faster than normal, because it was backed by the second ball and propellant.
The second ball would travel at a slower speed than normal, because the powder ahead of it would reduce its acceleration.
As phrased, this is going to be hard to answer because so much is going to depend on the seriously unpredictable details of exactly how the combustion propagates within the two charges. (And in the unlikely event that you are considering actually trying this.... Don't. These details mean that the outcome is also seriously unpredictable - bursting the barrel and killing someone even after calculations show you have plenty of safety margin is a possibility).
You might try restating the problem with the explosive charges replaced by compressed coil springs - the behavior will be more predictable and easily analyzed.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
