Superposition and entanglement
In summary: You cannot really have a 'position' of a photon in the same sense that you might have a position of a particle in classical physics.
San K
911
Entanglement is a type/product of superposition.
How is entanglement different from other kinds of superposition?...such as when a photon is a superposition of all possible paths/locations
Any quantum system, even a singe indivisble particle can be in a superposition.
Entanglement requires that the system can be divided into two parts. The two parts are entangled if the state of the whole system cannot be written as a product of the state of each part (ie. it must be written as a superposition of products).
One way to determine if the two parts are entangled is by the entanglement entropy of the reduced density matrix of one part. http://www-thphys.physics.ox.ac.uk/people/JohnCardy/seminars/born1.pdf
Well answered atyy.
what could a single indivisible particle be in a superposition with? ...it's own spin states?
Would a single indivisible particle, invariably, have to be in some sort of superposition, at all times, on some of its properties?
You can also have entanglement for single particles. An example is the Stern-Gerlach experiment, where spin and position get entangled so that detecting the particle at a certain position tells you its spin.
I would say entanglement is possible if you have compatible observables. Two observables A and B are compatible, if a basis of common eigenstates exists for them. So there is a complete set of states, where a measurement of A doesn't change the outcome of a subsequent B measurement. So you can change the values for A independent of B. Note that entangled states are exactly the states which don't have this property. The criterion is that states with this property exist, not that all states have it.
For a single particle, position and spin (projection) are compatible. A particle with a fixed spin projection can be at any position and vice versa. Position and momentum are not compatible because the position wavefunction ψ(x) restricts the possible values of the momentum.
For a composite system, all observables which involve a measurement on only one of the parts are compatible. So if we have two particles, we can entangle all single particle observables (position, momentum, spin, ...) of one particle with all single particle observables of the other.
Likes 2 people
Good informative post kith.
kith said:
You can also have entanglement for single particles. An example is the Stern-Gerlach experiment, where spin and position get entangled so that detecting the particle at a certain position tells you its spin..
I browsed through the Stern-Gerlach experiment.
Is the in-homogeneous field used to entangle spin and position?
What percentage gets entangled?
Or is spin and position already entangled?... to being with
on a separate note:
Both the Stern Gerlach (Magnetic field) and an experiment with polarizers:
are not merely selectors/filters but actually alter the state of the photon/electron.
Can polarizers also cause spin and position entanglement?
Yes.
No. Initially, you have only one beam, so a position measurement doesn't tell you anything. After the interaction with the magnetic field, you have two beams with perfect correlations between spin projection and position.
No. A polarizer simply takes a superposition and collapses it. A SG apparatus doesn't need to cause collapse. If you don't block the beams, you can perform further experiments with the entangled final state. In other words, it is not the magnetic field which "measures" the system but the optional subsequent position measurement.
Also the very concept of photon position is a notoriously troublesome one.
FAQ: Superposition and entanglement
What is superposition?
Superposition is a quantum mechanical principle that states that a quantum system can exist in multiple states or positions simultaneously until it is observed or measured.
What is entanglement?
Entanglement is a quantum mechanical phenomenon in which two or more particles become connected in such a way that the state of one particle is dependent on the state of the other, even when they are physically separated.
How are superposition and entanglement related?
Superposition and entanglement are both quantum mechanical phenomena that occur at the subatomic level. Superposition allows for multiple states to exist simultaneously, while entanglement describes the correlation between particles that can exist in a superposition state.
What is the significance of superposition and entanglement?
Superposition and entanglement are fundamental principles of quantum mechanics that have revolutionized our understanding of the nature of reality. They have also led to the development of technologies such as quantum computing and cryptography.
How do scientists study superposition and entanglement?
Scientists use a variety of experimental techniques, such as quantum interferometry and Bell tests, to observe and manipulate superposition and entanglement. These experiments help us better understand the behavior of quantum systems and how to harness their potential for new technologies.
