Superposition Angle Range in 2-Slit Experiment
  • I
  • Thread starter Jsauce
In summary, superpositions can be created by matrices, and there is a finite number of them. The slits in a 2-slit experiment must be within a certain distance to reproduce the experiment, and the boundaries of the uncertainty in the direction of the beam are undefined.
Jsauce
TL;DR Summary
Question on superpositions
With superpositions, the matrix based equations imply that there is a finite number of possible superpositions. Descriptions of how to reproduce the 2-slit experiment prescribe a maximum distance the slits can be apart and still reproduce the experiment.
is there a way to determine the minimum and maximum angles a superposition could have from the emitter?
Jsauce said:
Summary:: Question on superpositions
This question does not make much sense to me. For a double slit experiment, you need the slits to be within the uncertainty in the direction of the beam. But, also, if the slits are far apart and you have a very large uncertainty in the direction of the beam, then you will effectively get two separate single slit patterns, some distance apart.
Likes berkeman
What defines the boundaries of the uncertainty?
There is no definite boundary, but the probability distribution will drop off very quickly for a tightly focused beam.
So there is a non-zero chance that a single photon could impact a detector 180 degrees behind the emitter?
That's not really relevant. If the emitter is a simple source, then photons will be detected in all directions. If the emitter produces a focused beam, then the probability of being detected outside a narrow strip on the first screen would be vanishingly small.
Helpful as ever
Likes berkeman
FAQ: Superposition Angle Range in 2-Slit Experiment
What is the Superposition Angle Range in a 2-Slit Experiment?
The Superposition Angle Range in a 2-Slit Experiment refers to the range of angles at which the two interfering waves from the two slits are in phase, resulting in constructive interference and producing a bright fringe on the screen.
How is the Superposition Angle Range determined?
The Superposition Angle Range is determined by the distance between the two slits, the wavelength of the incident light, and the distance between the slits and the screen.
What happens if the incident light has a shorter wavelength?
If the incident light has a shorter wavelength, the Superposition Angle Range will be narrower, meaning that the bright fringes will be closer together on the screen. This is because shorter wavelengths have a higher frequency and therefore require a smaller angle to be in phase.
What is the significance of the Superposition Angle Range in the 2-Slit Experiment?
The Superposition Angle Range is significant because it determines the spacing of the bright fringes on the screen and provides valuable information about the properties of light, such as its wavelength and frequency.
Can the Superposition Angle Range be altered?
Yes, the Superposition Angle Range can be altered by changing the distance between the slits or the distance between the slits and the screen. It can also be altered by using light of a different wavelength.
