Superposition betweeen Boson and Fermion
In summary, the conversation discusses the possibility of putting a boson and fermion in superposition and the implications this has for quantum physics. While SpectraCat believes it is not possible due to symmetry principles, Vlatko Vedral and some other physicists are unsure and believe it is a technological limitation. Vedral also mentions the existence of two types of particles, fermions and bosons, and the potential for them to be in a superposition state. The conversation highlights the ongoing research and exploration of the boundaries of quantum physics.
Varon
548
Is it possible to put a Boson and Fermion in superposition? If not possible, why not?
Sure, what's wrong with:
[tex]\psi=(|B1>\otimes|F1> + |B2>\otimes|F2>)[/tex]
Where B1 and B2 are boson states and F1 and F2 are fermion states.
However, if you are asking if a wavefunction can be created for a superposition where a fermion exchanges with a boson, then I am almost 100% positive that the answer is no. The only possible exception I can think of is some high-energy particle physics process where fermions and bosons can be inter-converted, but I am not even sure that is theoretically possible. Exchange is a property of indistinguishable particles, and fermions are always distinguishable from bosons.
This is a very good question indeed. I take it to mean "if there is a state of a single boson [itex]|B\rangle[/itex] and a state of a single fermion [itex]|F\rangle[/itex], it the linear combination [itex]|B\rangle+|F\rangle[/itex] a 'good' state?". And the answer, as far as we know, is no!
This has to do with the topology of the Poincare group of spacetime symmetries (the rotations, boosts and translations). We can think just about the rotations for this. If you rotate by [itex]2\pi[/itex], a boson goes back to the same thing but a fermion picks up a minus sign. Each of these behaviours are fine on their own, because all we need when the states transform is what is called a projective representation, which means we don't care about a change in overall phase. But if you have the linear combination, what you end up with is not just a phase, so the combination is denied by the symmetry. This is what is called a 'superselection rule'.
The mathsy bit: The reason these 'projective representations' exists is because the rotation group is not 'simply connected', which means it has a hole: there are paths through the group which can't be contracted continuously to a point. If you want more on this, I'll be happy to expand a little; there is much more to be said!
That's not a superposition of a boson and a fermion state, since the two-particle system, consisting of a fermion and a boson is, of course, a fermion again. So you superpose two fermion states, and it's indeed "nothing wrong" with that.
Whether or not you allow certain superpositions or not is of course a question of observations, as any fundamental question in physics.
In theoretical physics you make models, often based on symmetry assumptions. Now, if you assume that rotational symmetry is realized in nature, this leads you to the mathematical assumption that you can realize the symmetry by a unitary or antiunitary ray representation of the according group. Thanks to Bargmann and Wigner's famous theorem any such symmetry can be lifted to an unitary or antiunitary representation of the covering group in Hilbert space. For the rotation group, SO(3), this means you investigate all unitary representations of its covering group, SU(2), which leads to the half-integer and integer-spin representations of rotations.
Now a rotation around [tex]2 \pi[/tex] should represent the identity. Now for particles with half-integer (integer) spin all their state vectors get multiplied by -1 (1). As long as you don't superpose states which belong to half-integer and integer-spin representations, there's no trouble with these phase factors since they are not observable. Thus, if you assume that nature respects rotational invariance and thus the Hilbert space admits a representation of the rotation group, one must not superimpose states, where one belongs to half-integer and the other to integer-spin representations. This is what is called a superselection rule: Certain linear combinations are forbidden since this would violate some symmetry principle.
Now, the spin-statistics theorem tells us that half-integer-spin (integer-spin) representations belong necessarily to fermions (bosons). Thus the rotational superselection rule forbids the superposition of a fermion and a boson state.
I was made aware of this superposition question between boson and fermion by Vlatko Vedral amazon book page (was referred to it after reading his June Scientific American cover story "Living in a Quantum World"). What do you think of the following? Is he talking about whether wavefunction can be created for a superposition where a fermion exchanges with a boson, which SpectraCat believes is not possible categorically? Vedral is a physicist. He is not sure the answer is no. Why? Anyone has same position as him or do all of you physicists share SpectraCat "almost 100% positive the answer is no"?
https://www.amazon.com/dp/0199237697/?tag=pfamazon01-20
"Vlatko Vedral: It is indeed depressing that quantum physics has been so consistently accurate over the past hundred years. There is really no obvious deviation from experiments (we physicists would get really excited if there were). The main issue I think is how general the quantum superposition principle is: Can any property really be superposed? Roger Penrose, for instance, believes that gravity will prevent superposing a massive object in two different places. Along with many other physicists, I think that this is a technological (not fundamental) problem. On top of this, we are far away from being able to experiment with time and space on scales relevant for quantum gravity. A more interesting issue for me (as well as being more readily accessible to experiments) is the existence of two different types of particles, fermions and bosons. It seems that every particle we observe is either a fermion (electrons, for example) or a boson (photons, for example). But can it be that we can have a particle in a superposition between a fermion and a boson? We are now in a position to be able to attempt to superpose these two properties in practice. If we show that this cannot be done, however, it is not clear what this means for quantum physics. Some of us like to think of everything in the universe as being quantum and finding limitations even in one aspect would tell us that there might be more out there…"
It's impossible to ever rule out the possibility of this sort of superposition theoretically, because of the way the superselection rule comes about. It relies on the assumption that we have a symmetry of a group that is not simply connected, like rotations SO(3). Then we can't superpose states that live in different projective representations.
BUT this is physically completely indistinguishable from a slightly different situation: We could have a case where the symmetry of nature is in fact a bigger group, the universal covering group (SU(2) in the case of rotations). This group is essentially several copies of the original group glued together. For example, SU(2) basically contains two copies of the rotation group and a 'rotation by 360 degrees' makes you jump between the two. This covering group is designed so that we don't need projective representations, so the superselection rule must then be imposed as an extra constraint: it really is a rule rather than a derived consequence. But then if we found that nature chose to break the rule, that would be fine: we would just conclude that it's not actually rotations that are the fundamental symmetry of nature, but the bigger group, and we throw out the superselection rules.
So AFAIK, while it would be interesting to find out that we could make these superpositions, I don't think it really has any serious consequences from a theoretical point of view. As to the practical consequences, I'm afraid you'll have to ask someone else, as I really don't know!
Can a boson state and a fermion state be superposed in a physically
sensible nontrivial way? I'm 100% certain the answer is "no", if local
Poincare symmetry holds. Actually, all we need is local rotational
invariance under boring old SO(3) so that boson and fermion
state spaces correspond to unitary irreducible representations
of that group.
The argument is given in Ballentine's textbook "QM - A Modern
Development", p183. Here's a quick summary. Consider a
hypothetical Hilbert space which is a direct sum of the boson and
fermion (1-particle) spaces. Denote two states from the boson
and fermions subspaces as
[tex]
|+\rangle ~~~ \mbox{and}~~~ |-\rangle
[/tex]
respectively. Denote by "R" the operator corresponding to
rotation by 2pi. Let A be any physical observable (which
Ballentine has already showed to commute with R). Then
[tex]
\langle+| R A |-\rangle ~=~ \langle+| A R |-\rangle
[/tex]
implying
[tex]
\langle+| A |-\rangle ~=~ - \, \langle+| A |-\rangle
[/tex]
and therefore
[tex]
\langle+| A |-\rangle ~=~ 0.
[/tex]
So, (in Ballentine's words),
Ballentine said:
Thus no physical observable can have nonvanishing
matrix elements between states with integer angular momentum and
states of half odd-integer angular momentum. This fact forms the
basis of a superselection rule.
One statement of this superselection rule is that there is no
observable distinction among the state vectors of the form
[tex]
|\Psi_\omega\rangle ~=~ |+\rangle + e^{i\omega} |-\rangle
[/tex]
for different values of the phase omega. [...]
Ballentine deals with nonrelativistic QM. But (afaict), passing to SR
or (local) GR doesn't change the argument because one still has
local SO(3) symmetry.
FAQ: Superposition betweeen Boson and Fermion
What is superposition between boson and fermion?
Superposition between boson and fermion is a quantum phenomenon where particles can exist in multiple states at the same time. This means that a particle can have properties of both a boson and a fermion simultaneously, which is not possible in classical physics.
How is superposition between boson and fermion different from regular superposition?
In regular quantum superposition, particles can exist in multiple states simultaneously, but they must be mutually exclusive states. However, in the case of superposition between boson and fermion, particles can exist in states that are usually considered exclusive, such as having both integer and half-integer spin at the same time.
What are some real-life applications of superposition between boson and fermion?
One potential application of superposition between boson and fermion is in quantum computing, where it can be used to create more efficient and powerful quantum algorithms. Additionally, it may also have applications in quantum teleportation and quantum cryptography.
Can superposition between boson and fermion be observed in the macroscopic world?
No, superposition between boson and fermion is a purely quantum phenomenon and cannot be observed in the macroscopic world. This is because the effects of superposition are only noticeable at the subatomic level, and as particles become larger, they behave more like classical objects.
How does superposition between boson and fermion impact our understanding of the universe?
Superposition between boson and fermion is a crucial concept in quantum mechanics, which is the theory that explains the behavior of particles at the subatomic level. It has revolutionized our understanding of the universe and has led to technologies such as transistors, lasers, and MRI machines. It also has implications for our understanding of fundamental concepts such as time and causality.
