Superposition Method for Finding Vout: Steps and Equations Explained
In summary, The conversation is about a circuit problem that involves using the superposition method to find Vout. The person has successfully found Vout1 by replacing the voltage source with a short circuit and performing basic analysis, but is stuck on finding Vout2. They are confused about how to deal with the open circuit that results from replacing the current source. The other person suggests using KVL and KCL to find the necessary values, but also questions the use of superposition in this particular circuit.
Cool hand Jak
See pdf attachment named Superposition .Find Vout
Steps of Superposition
I fount Vout1 by replacing the voltage source with a short circuit and doing basic d.c. analysis. My answer = 0.85V
However I'm stuck on how to find Vout2. I know you have to replace the current source with an open circuit. This however confuses me as there is now an open circuit in the middle of my circuit and I'm unsure what resistors, if any are in parallel and how to find the voltage across the load which is Vout2
Any help is greatly appreciated.
Thanks
  • Superposition.pdf
I am not sure which V you are talking about. That network is really confusing to look at.
Could you maybe post your calculations for how you found Vout1 so I can tell where you are coming from?
So, for superposition, you know that you short Vsources and open Isources.
Now, you say that you are confused because there would be an open circuit in the middle of the circuit?
Well, that's not completely true. You would be "opening" the current source, which means you just re-draw the circuit without the current source and perform your analysis again.
Since all you have left is a Vsource, I would recommend using KVL to find all of the currents. That's a hint that you should use KCL to find all of the voltages.
The more I look at the circuit, I wonder why you are using superposition anyway?
FAQ: Superposition Method for Finding Vout: Steps and Equations Explained
What is the principle of superposition?
The principle of superposition states that in an undisturbed sequence of rock layers, the youngest layers are on top and the oldest layers are on bottom.
What is the importance of superposition in geology?
Superposition is important in geology because it allows scientists to determine the relative ages of rock layers and the order in which they were deposited. This information is crucial for understanding the history of the Earth and the processes that have shaped it.
How do scientists use superposition to determine the age of rocks?
Scientists use superposition to determine the relative age of rocks by comparing the layers of sedimentary rocks. The bottom layer is the oldest, while the top layer is the youngest. By analyzing the different layers, scientists can determine the order in which they were deposited and infer the relative age of the rocks.
Can superposition be used to determine the absolute age of rocks?
No, superposition alone cannot be used to determine the absolute age of rocks. To determine the absolute age, scientists use other dating methods such as radiometric dating, which measures the decay of radioactive elements within the rock.
Are there any limitations to the principle of superposition?
Yes, there are limitations to the principle of superposition. It assumes that the layers of rock have been undisturbed and that the deposition of rock layers has been continuous. However, geological processes such as folding, faulting, and erosion can disrupt the layers and make it difficult to determine their relative ages using superposition.
