Superposition of Moments of Inertia about Different CGs
In summary: IxxI1 + IyyI2 + IzzI3. This is also the same as the sum of the individual moments of inertia about each mass's c.g. Note that if I1 and I2 are the same, then Izz = I1I2.In summary, the tabular form of moments of inertia allows for easy calculation of the total moments of inertia of a composite body.
Enginerd
Hi all,
You can use superposition to add moments of inertia when they're calculated about the same center of gravity (cg), but let's say you calculate the moments of inertia of several elements of a system about one cg and then use the Parallel Axis Theorem to then reference the total moments for these elements back to the total system cg. Do you get the same answer?
I had assumed yes, but then did some math that's making me not so sure.
Most basic example:
Let's say I have 3 mass elements in a 3 dimensional space. I am given the mass and cgs (relative to a reference frame origin) of each element, as well as the moment of inertia of each element about its own cg.
I lump together two of the elements and treat this as a new element. I find the mass, cg_lumped, and moments of this new lumped element relative to cg_lumped. Next, I want to find the TOTAL moments of inertia of the lumped element plus the 3rd element relative to the total system cg - call it cg_total.
I end up with extra terms using the "lumped method." I guess it's nonlinear... I may have messed up my math and there may be a cleaner way to do it, but I just want a proof one way or another of whether the answer would be the same in general. My math focuses on the Ixx (inertia about the X axis through the cg) only.
Setup and math here
Thank you!
Alexa.
Enginerd said:
Hi all,
Most basic example:
Setup and math here
Thank you!
Alexa.
I've always found using a tabular form for calculating the moment of inertia of a composite body the clearest and most efficient way of organizing this type of calculation. It's a shame more textbooks don't illustrate this method, IMO.
Let's say that our composite body is composed of three masses, m1, m2, and m3. Each of these masses has a c.g. referenced to the origin [for example, the c.g. of m1 is (x1, y1, z1) ], and there are the moments of inertia for each mass referenced about each mass's c.g. To simplify the calculation, let's assume that I1 = Ixx for m1, etc.
The tabular form is set up like this:
Code:
Item   Mass  xcg  ycg  zcg   M*x    M*y    M*z   M*x^2   M*y^2   M*z^2   I
1      m1    x1   y1   z1  m1*x1  m1*y1  m1*z1 m1*x1^2 m1*y1^2 m1*z1^2  I1
2      m2    x2   y2   z2  m2*x2  m2*y2  m2*z2 m2*x2*2 m2*y2^2 m2*z2^2  I2
3      m3    x3   y3   z3  m3*x3  m3*y3  m3*z3 m3*x3^2 m3*y3^2 m3*z3^2  I3
Total   M     x'   y'   z'   M*x    M*y    M*z   M*x^2   M*y^2   M*z^2   IT
M = m1 + m2 + m3
Mx = m1*x1 + m2*x2 + m3*x3
My = m1*y1 + m2*y2 + m3*y3
Mz = m1*z1 + m2*z2 + m3*z3
Mx^2 = m1*x1^2 + m2*x2^2 + m3*x3^2
My^2 = m1*y1^2 + m2*y2^2 + m3*y3^2
Mz^2 = m1*z1^2 + m2*z2^2 + m3*z3^2
IT = I1 + I2 + I3
x' = Mx / M
y' = My / M
z' = Mz / M
To calculate IT' about the centroid (x', y', z'):
IT' = IT + My^2 + Mz^2 - M * (y'^2 + z'^2)
Here, it's understood that IT' represents Ixx'.
The tabular form can be easily extended to handle Iyy and Izz, not to mention the products of inertia Ixy, Iyz, and Ixz.
Tablular form calculations can also be easily programmed into a spreadsheet to make evaluating actual numerical values that much easier.
Likes StewB
Thanks for the reply!
I should have mentioned that I have a MATLAB script calculating mass properties, and have also used a spreadsheet calculation to double check. However, using the two different methods I describe above I have not been able to get the answers to match. I resorted to the hand calcs to prove to myself that they should theoretically should match, but in fact I seem to have proven the opposite.
I would recommend that you post your calculations, especially in the spreadsheet form. There may be errors lurking within t which you may not have uncovered yet.
I would just like to know if it is theoretically possible to use the lumped method I described and attempted to prove valid mathematically. My question is really regarding the validity of my proof, not my actually mass properties calculations. For the sake of this question one could really assume I'm not actually doing any actual calculations but just wanted to understand if i could use the lumped approach in theory :). The actual numbers are not important.
You should get the same result regardless of how you lump the individual masses. I didn't look at all of your derivation because it gave me a headache. It would be much easier to follow one of your calculations, IMO.
I suspect that you have made an error in applying the Parallel Axis Theorem between the different groupings of masses. To apply the PAT correctly, you must first calculate everything about a common reference and then move it to a centroidal location using the PAT. If you are using multiple groupings of masses, this can get tricky. The tabular form eliminates problem this since you just add another row for an additional mass.
Haha it gave me a headache as well. I will try to get a sample calc and post it.
FAQ: Superposition of Moments of Inertia about Different CGs
What is the concept of "superposition of moments of inertia about different CGs"?
The superposition of moments of inertia about different CGs is a concept in physics that involves combining the moments of inertia of an object around different axes to calculate the total moment of inertia. This is applicable to objects with multiple axes of rotation or objects with changing center of mass.
How is the total moment of inertia calculated using superposition of moments of inertia?
To calculate the total moment of inertia using superposition, you need to add or subtract the moments of inertia of the individual components of the object around the same axis. This is based on the parallel and perpendicular axis theorems which state that the total moment of inertia of an object is equal to the sum of the moments of inertia of its individual components around the same axis.
What are the applications of superposition of moments of inertia about different CGs?
The concept of superposition of moments of inertia is widely used in mechanical engineering, robotics, and aerospace industries. It is used to calculate the moment of inertia for complex systems and structures, such as aircraft wings, car engines, and rotating machinery.
How does the distribution of mass affect the moments of inertia of an object?
The distribution of mass in an object plays a crucial role in determining its moments of inertia. Objects with a larger concentration of mass towards the center of mass will have a smaller moment of inertia compared to objects with mass distributed farther away from the center of mass.
Can the moments of inertia of an object change with different CGs?
Yes, the moments of inertia of an object can change with different CGs. This is because the moment of inertia is directly proportional to the square of the distance from the axis of rotation. So, if the CG of an object changes, the distance of the individual components from the axis of rotation will also change, resulting in a different moment of inertia.
