Superposition of two simple harmonic motion
The discussion revolves around summing two simple harmonic motions represented by the equations cos(t+5325) and 1.5 cos(t+5325). The correct approach to sum these equations is to combine the coefficients, resulting in 2.5 cos(t+5325). However, when the second term changes to 1.5 cos(t-5325), the equations cannot be directly combined due to differing arguments, and thus the sum does not simplify to a single cosine function. The final clarification emphasizes that the two terms must have the same argument to be summed directly. Understanding the conditions for combining harmonic motions is essential for solving such problems.
Krokodrile
find the sum of cos (t+5325) + 1.5 cos (t+5325)
X1 `+ X2
Hey! I am stuck in this problem, i don't know how to sum this ecuations.
I remember that its possible because the direction is the same
So, i try to sum like this:
cos (t+5325)
1.5 cos (t+5325)
=1.5 cos (t+5325) I don't know if i fine. I thanks your help, please ;)
Krokodrile said:
Homework Statement:: find the sum of cos (t+5325) + 1.5 cos (t+5325)
Relevant Equations:: X1 `+ X2
cos (t+5325)
1.5 cos (t+5325)
Maybe there is a typo in your post, but otherwise both terms are cos() with the same arguments. So what is 1+1.5?
oh, yes. I lose my mind for a second.
So, the answer would be:
2.5 cos (t+5325) ?
Likes Delta2 and berkeman
And...only a last question: in the case that 5325 have a negative sign like:
cos (t+5325)
1.5 cos (t-5325)
=2.5 cos (t) ??
thank you so much for you help
cos (t+5325)
1.5 cos (t-5325)
=2.5 cos (t) ??
No.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
