Superposition or just unobserved states?
That might not be true, for example, if the choice of axis is made by a conscious being, like a human experimenter.There's no way to rule out that possibility.In summary, the conversation discusses the concept of entanglement and how it relates to the observation of particles. One person is struggling to understand how the observation of one particle can affect the state of the other, and asks for clarification on the concept. Another person explains that there are differences between the predictions of quantum mechanics and other theories, which have been tested experimentally and support the quantum mechanical prediction. They also mention that the idea of pre
davezap
Can the kind members of this forum please help me make the logical leap from an entangled pair of electrons or photons to that of the pair being in a superposition where the observation of one effects the state of the other?
For example, my understanding is that, through the conservation of angular momentum we can have a particle decay into two entangled electrons one spin-up and the other spin-down. Further when we measure the spin of one of these electrons and find that 50% of the time we get the up and the other 50% must be down, and then can deduce the state of the idler with 100% certainty.
So what I'm missing here is how observation of the signal in any way effects the idler? I mean if we detect a spin-down then we know it was ALWAYS spin-down when it was created - don't we?
An analogy might be their are two roads to your house, you hear a knock at your door and upon opening it you see your good friend. You know your friend must have taken one of the two roads or else he would not be standing in front of you. Opening the door did not change what road he took in the past though?
Isn't it just simple to say that we didn't know the state prior to observing it? and that the observation had no influence on the outcome of states?
I'm sure this has been done to death experimentally and so perhaps I could be pointed to the appropriate experiment that demonstrates the so called "spooky action at a distance".
I'm sure this an obvious question from someone who has a casual interest in physics and my question is probably born out of reading lay person explanations that seldom include the math (not that I'm asking for a lot of that here). I feel I'm missing something fundamental at this point.
I realize there is an open question on the forum "Meaning of Observation" however I think mine while related is asking something completely different. That question is basically asking what is considered a detector, I'm asking how does detection change anything at all.
Thanks.
davezap said:
So what I'm missing here is how observation of the signal in any way affects the idler? I mean if we detect a spin-down then we know it was ALWAYS spin-down when it was created - don't we?
That's what we'd expect based on lifetime of experience with macroscopic objects, but it is not that way. Google and search this forum for "Bell's theorem".
The summary: There are subtle differences between the predictions of quantum mechanics and the predictions of any theory in which the spin had a definite value from the time the pair was created. These differences can be tested experimentally and they support the quantum mechanical prediction and cannot be reconciled with any theory in which the spin has definite value and we just didn't know what it was until we measured it.
Likes dlgoff and vanhees71
A question :
Is it OK to say that if we measured the values, what we (would) get must be eigenvalues of some operator ? Or is that exactly what is forbidden ?
As @Nugatory said, that interpretation is ruled out by detailed analysis of the predictions of quantum mechanics.
The problem is that spin is a vector, not just a number. So for any direction in space [itex]\vec{D}[/itex], we can measure the electron's spin along the [itex]\vec{D}[/itex] axis. In the case of entangled electron/positron pairs, if one experimenter measures the spin along axis [itex]\vec{D}[/itex], and gets spin-up for one particle, then the other experimenter will get spin-down for the other particle along that axis.
So what this means* is that your explanation, that the correlations are due to pre-existing values, would imply that for every possible direction [itex]\vec{D}[/itex], it is determined ahead of time whether the particle has spin-up or spin-down in direction [itex]\vec{D}[/itex].
So let's pick three different directions: [itex]\vec{a}[/itex] is along the y-axis, [itex]\vec{b}[/itex] is in the x-y plane at an angle of 120o clockwise away from [itex]\vec{b}[/itex], and [itex]\vec{c}[/itex] is in the x-y plane at an angle of 240o away from [itex]\vec{a}[/itex]. So if you're right, that the results are pre-determined, then that means that there are 8 different types of situations with regard to our three axes:
  1. The electron is spin-down along all three axes. (And the positron is spin-up along all three). We'll label this case DDD.
  2. The electron is spin-down along \vec{a}, \vec{b}, but spin-up along \vec{c}. The positron is the opposite. We'll label this case DDU.
  3. Etc.
There are 8 possible spin-states: DDD, DDU, DUD, UDD, UDU, UUD, UUU
So let's assume that when we have an entangled electron/positron pair, that the electron is in one of those states, with a certain probability.
In order to reproduce the experimental results (and the predictions of quantum mechanics), these 8 states have to have the following probabilities:
P(UUU) = P(DDD) = -0.0625
P(UUD) = P(UDU) = P(DUU) = P(UDD) = P(DUD) = P(DDU) = 0.1875
Obviously, something can't have a negative probability, so this interpretation is impossible.
As to how those numbers are derived, I can give a little more details, if you like.
*Superdeteriminism loophole
The argument assumes that the choice of which axis to measure the electron's spin relative to is independent of the spin-state of the electron. You could imagine that this is not the case. Maybe even though the experimenter thinks he is making a random choice as to which axis to measure, the choice is actually determined ahead of time. This is the superdeterminism loophole.
In a projective measure of spin for instance the spin direction is changed by a physical rotation .
See https://en.wikipedia.org/wiki/Stern–Gerlach_experiment
Mentz114 said:
A question :
No, that's OK. In fact, that's exactly pretty much what the Born rule says.
Thanks for pointing me in that direction, I've come across a few descriptions relating to linear polarization and the probabilities therein. That's strange enough for me at the moment :) and is the simple experimental demonstration I was looking for in my original question.
Thanks for your explanation it does help but going deeper into the math might loose me. What I'm getting from Bell is that only two explanations for the quantum observations exist, either hidden local variables are at work or faster than light communication, between the particles. If local hidden variables are ruled out then EPR is wrong, and this has been experimentally demonstrated to be so. Still increasingly elaborate experiments are performed to close the remaining loopholes. I think these loopholes related to non-local hidden variables? and having enough distance between detectors to rule out.. but anyway please don't explain all that as it's way off topic.
At this point I need to digest it a little more.If either of you or anyone else can recommend a good primer on the broad QM topic (as in a paper book / Amazon) my time would be better served getting to grips with the basics. It's been a few years since I did my engineering degree, but think I can get a handle on the maths again as I understand it's all vectors, matrices and complex numbers (more or less) things they make engineers learn believe it or not ;)
[edit] just for clarification I'm looking for a textbook that explains the math and gives explanations of experimental setups and observations if such a book exists. I'm not looking for pop-science '10 fun facts to wow your friends at the pub'
Also purchasing a few cheap polarizes is well within my capability to satisfy my apparent need to understand through experimentation.
Thanks again.
"ALWAYS" is an interesting word in this context. It presupposes the concept of time -- something we understand very little about.
This particular aspect of the quantum paradigm is rarely discussed. If there is anyone on this forum who knows of any published papers that address the issue of what "always" means between state preparation and state detection I would love to now about it.
Your friend can tell you what road they took. A particle cannot tell you what they were doing before you detected it.
This particular aspect of the quantum paradigm is rarely discussed. If there is anyone on this forum who knows of any published papers that address the issue of what "always" means between state preparation and state detection I would love to now about it.Your friend can tell you what road they took. A particle cannot tell you what they were doing before you detected it.
Well yes :) I just threw the word ALWAYS in without much thought but did intend to mean from the time the pair were created onward to the time of detection.
After a little more reading I'm happy with the idea that QM provides a mathematical framework to explain observations and that is where it meets it's limit. QM is not a branch of philosophy however interpretation of what QM might 'mean' is.
I am not sure if I understand the question entirely. This is my take on it:
Suppose we have to measurement apparatusses M1 and M2, and a pair of entangled particles Ea and Eb. Suppose M1 and M2 have their measurement axis aligned parallelly. Now we create Ea and Eb, and send Ea to M1 and Eb to M2.
(A) Now, if we measure the spin of Ea to be 'down' at M1, we measure Eb to be 'up' at M2.
(B) However, we could decide to turn the orientation of M1 and M2 clockwise or anticlockwise while the particles are already in transit, keeping them parallel. If we now measure Ea to be 'down' at M1, still we will measure Eb to be 'up' at M2.
Now, could we say that the spin of Eb was 'up all along'? The orientation that is measured differs between (A) and (B)! Which orientation would the spin have had?
The matter is that the outcomes on M1 and M2 depend on the relative orientation of M1 and M2, and not so much on the spin property of Ex (if it even has one).
A general pure spin state can be described with the vector
$$|\psi \rangle=a |1/2 \rangle+b |-1/2 \rangle,$$
where ##\langle \psi|\psi \rangle=|a|^2+|b|^2=1##.
According to Born's rule, the probability to find spin up when measuring ##\sigma_z## is
$$|\langle 1/2|\psi \rangle|^2=|a|^2.$$
Likes davidge
Related to Superposition or just unobserved states?
1. What is superposition?
Superposition refers to the principle in quantum mechanics that states a quantum system can exist in multiple states or positions simultaneously until it is observed or measured. This means that an object or particle can exist in multiple locations or states at the same time.
2. How does superposition occur?
Superposition occurs when a quantum system is in a state of uncertainty, meaning it has not yet been observed or measured. The system exists in a combination of all possible states until it is observed, at which point it collapses into one specific state.
3. Can superposition be observed in everyday life?
No, superposition is only observed at the quantum level and is not observable in everyday life. This is because quantum systems are extremely small and delicate, making it difficult to maintain superposition on a large scale.
4. What is the significance of superposition?
Superposition is significant because it challenges our classical understanding of the world and allows for the possibility of objects existing in multiple states at once. It also plays a crucial role in quantum computing and other quantum technologies.
5. How does superposition relate to the Heisenberg Uncertainty Principle?
The Heisenberg Uncertainty Principle states that it is impossible to know both the position and momentum of a particle with complete certainty. Superposition is related to this principle because it allows for the simultaneous existence of multiple positions and momentums until the particle is observed or measured.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
