Superradiance and the assumption of indiscernable atom field coupling
In summary: If you have an indistinguishable situation, that also means your atoms will coherently radiate in phase with each other. That makes a huge difference. For independently radiating atoms, you will get an intensity proportional to N (the number of atoms). Basically you just take the field of each individual atom, square it and sum up the intensities.
McLaren Rulez
292
Hi,
If we have a system on N atoms confined to dimensions much smaller than the wavelength corresponding to the transition, we see superradiant decay. Now, in these cases, we always assume that the excitation is symmetrically or antisymmetrically distributed. For instance, if we have one excitation among N atoms, an example of an initial state is
[tex]
\mid\psi\rangle=\frac{1}{\sqrt{N}}\sum_{j}\mid g_{1}g_{2}..e_{j}..g_{N}\rangle
[/tex]The claim is that the correct treatment of superradiance needs to assume that the atomic ensemble couples to the field in an indiscernible way. In other words, there is no way to know which atom emitted the photon. Why is this assumption necessary and why does it correctly describe superradiance?
Why can I not say, for instance, that the kth atom is excited and all others are in the ground state? Remember, we are not doing an actual experiment so for our purposes, all the atoms are just dipoles and no dimensions have been specified for the atoms.
Thank you!
This is a bit like asking, why we need to assume indistinguishability in the double slit experiment and cannot just have a look at two individual slits.
For indistinguishable atoms you cannot neglect phase and you cannot sort one field to one atom. So you have to sum up all the fields (or probability amplitudes if you want a quantum optics treatment). This sum will be proportional to N. Now you need to square afterwards to get the intensity, which will obviously go as N^2.
Thank you for replying. I see your point.
Related to Superradiance and the assumption of indiscernable atom field coupling
1. What is superradiance?
Superradiance is a phenomenon where a large number of atoms or molecules emit light in a synchronized and coherent manner. This results in a much stronger and more directional emission compared to individual atoms or molecules.
2. How does superradiance occur?
In order for superradiance to occur, there must be a collective coupling between atoms or molecules and an electromagnetic field. This coupling causes the atoms to synchronize their emission, resulting in a superradiant burst of light.
3. What is the assumption of indiscernible atom field coupling?
The assumption of indiscernible atom field coupling states that the coupling between atoms and the electromagnetic field is identical for all atoms within a superradiant system. This assumption is necessary for the synchronized emission of superradiance.
4. Is the assumption of indiscernible atom field coupling always valid?
No, the assumption of indiscernible atom field coupling may not be valid in certain situations such as when there are variations in the properties of individual atoms or when the atoms are not in identical environments. In these cases, the superradiant emission may be weaker or not occur at all.
5. How is superradiance relevant in scientific research?
Superradiance has various applications in fields such as quantum optics, laser physics, and astrophysics. It also has potential uses in technology, such as in the development of more efficient lasers and in quantum computing.
  • Atomic and Condensed Matter
  • Quantum Physics
  • Quantum Physics
