Suppose a, b, c are three real numbers such that
In summary, setting a = ax2 b= bx c =c in the character equation will result in a solution that is -B/2A from r1 to r2, but if x equals 1, the ODE will be 0.
nysnacc
184
character equation
Should I set a = ax2 b= bx c =c in the character equation?
Hi, you must start to substitute ##y_{1}(x)=x^{r_{1}}## in the differential equation and find ##r_{1}## that satisfy the equation ...,
so start to calculate ##y'_{1}(x)## and ##y_{1}''(x)## ...
The same for ##y_{2}(x)=x^{r_{2}}\ln{x}## ...
y1 = xr1
y1' = r1* xr1-1
y1" = r1 (r1-1)* xr1-2 = ( r12 - r1) *xr1-2
then plug in ODE?
Then (I simply say r instead of r1)
a(r2-r)xr +b r xr + cxr
xr ( a(r2-r) + b r +c )
And solve for r ?
And solve for r ?
You can't solve the above, because they aren't equations!
The equation you need to solve is a(r2-r)xr +b r xr + cxr = 0,
which is equivalent to xr ( a(r2-r) + b r +c ) = 0
Now solve for r.
Oh yeah! but I don't know a, b and c... there are four unknowns then
But you have a relationship involving a, b, and c given in your problem statement.
So I solve for r which is r = ... (in terms of a, b, c) probably be -b +/- sqrt (b^2 - 4 ac) / 2a
Then use the relationship involving a, b, and c given in problem statement?
But do I need one more equation?
For r1, it is -B/2A which is -(b-a)/2a
Do I end up wth the letter as coefficient, or any further?
No it isn't.
Start from this:
The part on the left has to be identically equal to zero; i.e., for all values of x.
So either xr = 0 (can't be true)
or a(r2-r) + b r +c = 0
Solve this equation for r.
Yes, this is what I get: r = -(b - a)/(2a), which is the same as (a - b)/(2a)
Likes nysnacc and Ssnow
Great, so this is it, for r1 ?? :)
Likes Ssnow
Yes.
For r2,
I have y2 = xr2 ln (x)
y2' = xr2-1 +r2 xr2-1 ln (x)
y2" = (r2-1)xr2-2 +r2 xr2-2 + (r2^2-r2)xr2-2 ln(x)
Which then plug into the ODE, i found r2 = -(b-a)/ 2a same as r1
and whole ODE can be 0 if x =1
FAQ: Suppose a, b, c are three real numbers such that
What is the definition of "Suppose a, b, c are three real numbers such that"?
"Suppose a, b, c are three real numbers such that" is a phrase commonly used in mathematical equations to indicate that the given variables have a specific relationship or condition that must be satisfied within the equation.
What are the possible relationships between a, b, and c in the phrase "Suppose a, b, c are three real numbers such that"?
The possible relationships between a, b, and c can vary depending on the context of the equation. Some common relationships include a is equal to b, a is less than b, a is greater than b, a is equal to the sum of b and c, and a is equal to the product of b and c.
Can a, b, and c be any type of numbers in the phrase "Suppose a, b, c are three real numbers such that"?
No, in this phrase, a, b, and c are specifically identified as real numbers. This means that they are all numbers that can be represented on a number line and include both positive and negative numbers, as well as fractions and decimals.
What is the purpose of using the phrase "Suppose a, b, c are three real numbers such that" in a mathematical equation?
The purpose of using this phrase is to establish a specific relationship or condition between the given variables a, b, and c. This helps to clarify the parameters of the equation and provides a starting point for solving the equation.
Are there any restrictions on the values of a, b, and c in the phrase "Suppose a, b, c are three real numbers such that"?
There may be restrictions on the values of a, b, and c depending on the context of the equation. For example, if the equation involves square roots, then a, b, and c must be non-negative numbers. It is important to carefully consider any restrictions when using this phrase in a mathematical equation.
