Suppose y is directly proportinal to x
  • Thread starter mech-eng
In summary, the given information states that y is directly proportional to x, and this can be represented by the equation y = ax, where a is a constant. Using this information, we can show that y is a linear function of x, with a slope of 0.04 for the first line and 0.067 for the second line. The concept of proportionality is important in understanding the relationship between x and y, where doubling the value of x doubles the value of y.
mech-eng
828
[/B]
Suppose that y is directly proportional to x. Show that y is a linear function of x. Both lines goes through the origin. First line goes 1250 ft in x direction and 50 ft in y direction. The second line goes 13740 ft in x direction and 920.58 ft in y direction.
Source: Algebra and Trigonometry by Keedy/Bittinger.
y=mx+n[/B]
1.y=mx+n since line goes through the origin y-intercept is 0. We know y-intercept and slope then we can write a slope-intercept equation for the line. m=50/1250=0.04; y=0.04x
2. y=mx+n since line goes through the origin y-intercept is 0. We know y-intercept and slope then we can write a slope-intercept equation for the line. m=0.067x
But here I do not understand why the information "y is directly proportional to x" is given? What are other ways to solve this problem?
Thank you.
[/B]
Its given cause its implies x is proportional to y. Like y=ax where a is a constant reel number this function like y=ax so f(x)=ax is a linear function.I don't think there's any other way to solve this question.
Isn't y in y=x2directly proportinal to x?
Its not
If y is directly proportional to x, then doubling the value of x doubles the value of y.
How is this square case of proportionality called?
Thank you.
"y is proportional to x squared"
Mathematically, it is the difference between ##y \propto x## and ##y \propto x^2##.
Thank you.
##y## proportional to ##f(x)## just means that ##y/f(x)## is a constant; that is, ##y = c f(x)## for some constant ##c##.
What's with the question numbers (50,51,52)? Is 50 referring to 51 and 52?
I think 50 is the question and 51 and 52 are parts of it. That's all in the picture.
Thank you.
FAQ: Suppose y is directly proportinal to x
What does it mean for y to be directly proportional to x?
When two variables, y and x, are directly proportional, it means that as the value of x increases, the value of y also increases at a constant rate. Similarly, as the value of x decreases, the value of y also decreases at the same constant rate.
How can I recognize a direct proportionality between y and x?
A direct proportionality between y and x can be recognized by plotting the values of y and x on a graph and observing a straight line passing through the origin (0,0). The slope of this line represents the constant rate at which y changes with respect to x.
What is the formula for calculating direct proportionality between y and x?
The formula for calculating direct proportionality between y and x is y = kx, where k represents the constant of proportionality.
Can the constant of proportionality, k, ever be equal to 0?
No, the constant of proportionality, k, cannot be equal to 0 because this would mean that y is not dependent on x and there is no direct relationship between the two variables.
How can I use direct proportionality to solve real-world problems?
Direct proportionality can be used to solve real-world problems by setting up a proportion between two related quantities and using the constant of proportionality to calculate the unknown value. For example, if it takes 2 hours to drive 100 miles, we can set up the proportion 2 hours / 100 miles = x hours / 200 miles to find the time it would take to drive 200 miles at the same constant rate.
