MHB Supremum Property (AoC), Archimedean Property, Nested Intervals Theorem ....
Math Amateur
MHB
I am reading Houshang H. Sohrab's book: "Basic Real Analysis" (Second Edition).
I am focused on Chapter 2: Sequences and Series of Real Numbers ... ...
I need help with Theorem 2.1.45 concerning the Supremum Property (AoC), the Archimedean Property, and the Nested Intervals Theorem ... ...
Theorem 2.1.45 reads as follows:View attachment 7166
https://www.physicsforums.com/attachments/7167My questions regarding the above text from Sohrab are as follows:Question 1
In the above text we read the following:
" ... ... $$s + \frac{m}{ 2^n}$$ is an upper bound of $$S$$, for some $$m \in \mathbb{N}$$. Let $$k_n$$ be the smallest such $$m$$ ... ... "Can we argue, based on the above text, that $$s + \frac{m}{ 2^n} = \text{Sup}(S)$$ ... ... ?
Question 2
" ... ... We then have $$I_n \cap S \ne \emptyset$$ (Why?) ... ... "Is $$I_n \cap S \ne \emptyset$$ because elements such as $$s + \frac{ k_n - x }{ 2^n} , 0 \lt x \lt 1$$ belong to $$I_n \cap S$$ ... for example, the element $$s + \frac{ k_n - 0.5 }{ 2^n} \in I_n \cap S$$?
Is that correct ... if not, then why exactly is $$ I_n \cap S \ne \emptyset$$?Hope someone can help ...
Peter==========================================================================================The above theorem concerns the Supremum Property, the Archimedean Property and the Nested Intervals Theorem ... so to give readers the context and notation regarding the above post I am posting the basic information on these properties/theorems ...https://www.physicsforums.com/attachments/7168
https://www.physicsforums.com/attachments/7169
Peter said:
Question 1
No. What is happening in this proof is that you narrow down the location of $\sup(S)$ by an approximation process. You start from a point $s$ in $S$, and having fixed $n$, you look at the points $s + \frac1{2^n}, s + \frac2{2^n}, s + \frac3{2^n}, \ldots$, until you find the first point $s + \frac{k_n}{2^n}$ that is an upper bound for $S$. That way, you have narrowed down the location of $\sup(S)$ to an interval $I_n$ of length $\frac1{2^n}$. You then increase $n$ to $n+1$, so as to locate $\sup(S)$ within a smaller interval $I_{n+1}$ (which must be either the first half or the second half of the previous interval $I_n$).
Peter said:
Question 2
Since $k_n$ is the smallest integer for which $s + \frac{k_n}{2^n}$ is an upper bound for $S$, it follows that $s + \frac{k_n-1}{2^n}$ is not an upper bound for $S$. Therefore there is an element, call it $t$, of $S$ that is greater than $s + \frac{k_n-1}{2^n}$. But $t\leqslant s + \frac{k_n}{2^n}$ (because $s + \frac{k_n}{2^n}$ is an upper bound for $S$), and so $t$ lies in the interval $I_n$. So $t$ lies in the intersection $I_n\cap S$.
Opalg said:
No. What is happening in this proof is that you narrow down the location of $\sup(S)$ by an approximation process. You start from a point $s$ in $S$, and having fixed $n$, you look at the points $s + \frac1{2^n}, s + \frac2{2^n}, s + \frac3{2^n}, \ldots$, until you find the first point $s + \frac{k_n}{2^n}$ that is an upper bound for $S$. That way, you have narrowed down the location of $\sup(S)$ to an interval $I_n$ of length $\frac1{2^n}$. You then increase $n$ to $n+1$, so as to locate $\sup(S)$ within a smaller interval $I_{n+1}$ (which must be either the first half or the second half of the previous interval $I_n$).Since $k_n$ is the smallest integer for which $s + \frac{k_n}{2^n}$ is an upper bound for $S$, it follows that $s + \frac{k_n-1}{2^n}$ is not an upper bound for $S$. Therefore there is an element, call it $t$, of $S$ that is greater than $s + \frac{k_n-1}{2^n}$. But $t\leqslant s + \frac{k_n}{2^n}$ (because $s + \frac{k_n}{2^n}$ is an upper bound for $S$), and so $t$ lies in the interval $I_n$. So $t$ lies in the intersection $I_n\cap S$.
Thanks Opalg ... most helpful ...
... indeed, you made it very clear ...
Peter
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
