To determine the surface absorptance of a material without knowing its radiant emittance, one can illuminate the surface using a square wave modulated or pulsed light source. The reflected energy should be detected as an AC signal, allowing for analysis of the surface's response. The DC output measured will correspond to the emittance of the material. This method enables the calculation of absorptance by isolating the effects of emittance. Accurate measurements can lead to a better understanding of material properties in thermal applications.
#1
j1230
TL;DR Summary
surface absorption
how can I go about finding the surface absorptance of a material if I'm not given the radiant emittance of the non- black body?
Illuminate the surface with a square wave modulated or a pulsed source.
Then synchronously detect the reflected energy as an AC signal.
The DC output will be due to emittance of the body.
This is what I am thinking. How much feasible is it?
There is a white hole inside every black hole
The white hole spits mass/energy out continuously
The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole
Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole
Because of continuously spitting mass/energy which keeps...
i want to just test a linear generator with galvanometer , the magnet is N28 and the wire (Cu) is of 0.6mm thikness and 10m long , but galvanometer dont show anthing ,
The core is PLA material (3d printed)
The magnet size if 28mm * 10mm * 5mm
Why do two separately floating objects in a liquid "attract" each other ??
What if gravity is an emergent property like surface tension ?
What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other*
What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
