Surface area of revolution about y
In summary: I see.I drew a sketch of the curve and another of the surface of revolution. Doing that will help you derive the formula or at least use the right one.In summary, the surface area obtained by rotating the curve y = x^2/4 - ln(x)/2 is 1 \leq x \leq 2. The Attempt at a Solution can't seem to isolate for x in terms of y. I raised both sides to e and separated the exponents and rearranged. Giving me e^x^2/x^2 = e^(4y) but I'm stuck here. Thanks.
Tarpie
[/B]
Find the surface area obtained by rotating the curve
[itex]y = x^2/4 - ln(x)/2 [/itex]
[itex]1 \leq x \leq 2[/itex]
[itex]2π \int f(x)\ \sqrt{1+(f'x)^2} dx [/itex]
I can't seem to isolate for x in terms of y. I raised both sides to e and separated the exponents and rearranged. Giving me [itex] e^x^2/x^2 = e^(4y) [/itex] but I'm stuck here.
Thanks
Tarpie said:
[/B]
Thanks
Are you revolving this about the y-axis or about the x-axis?
Sorry y-axis. Could've sworn i wrote it
Yes, it's in the title. Just wanted to make sure. -- It is always best to include all information in the Original Post as well.
About the y-axis: should that be x rather than f(x) in the integral.
##\displaystyle\ 2π \int_1^2 x\, \sqrt{1+(f'(x))^2} dx\ ##Also, why do you want to find x in terns of y ?
Tarpie said:
I can't seem to isolate for x in terms of y. I raised both sides to e and separated the exponents and rearranged. Giving me e^x^2/x^2 = e^(4y) but I'm stuck here.
The LaTeX interpreter choked on your equation, and I can't make sense of it either. What is the left side supposed to be? With LaTeX, if an exponent is more than one character, you need braces. IOW, this -- ##e^2## (that is, e^2) is OK, but ##e^2x## (using e^2x) doesn't render the same as e^{2x} would.
SammyS said:
It is always best to include all sure information in the Original Post as well.
Yes. All the information should be in the post, not just in the title.
I see now. That x in your equation I'm used to thinking of as f(y), just like when you rotate the curve about the x-axis it's a y; i also see that as an f(x).
So for each radius which is each x value on the curve i thought I had to rewrite it as a function of y integrate over the y interval...just like how y=f(x) i thought x had to be f(y)...didnt realize you can just stick the actual x and y in by themselves, much more convenient.
Thanks a ton
Does this apply to volume as well or just surface area, because for volumes I've always rearranged for x as a function of y if it asks to rotate a curve about the y axis.
I would suspect it's just surface area because of that invariant arc length term
ya...because each point on that arc length is mapped to a certain x value regardless of whether in terms of y or x...so you can just use that x and the x interval instead of flipping it and using the y interval in terms just because it's about y...like rotation of height only sideways...anyways I am rambling
thank you
Not necessarily. This is true if the function happens to be one-to-one on the interval in question (your function is one-to one on the interval).
A big problem is that what you show as your relevant equation isn't relevant. Since the curve is being revolved around the y-axis, the radius is NOT f(x), but is instead x. The relevant formula here would be ##2\pi\int_1^2 x \sqrt{1 + (f'(x))^2}dx##. Did you draw a sketch of the curve and another of the surface of revolution? Doing that will help you derive the formula or at least use the right one.
Related to Surface area of revolution about y
What is the surface area of revolution about y?
The surface area of revolution about y is the total area of the 3-dimensional shape formed when a 2-dimensional curve is rotated 360 degrees around the y-axis.
How do you calculate the surface area of revolution about y?
To calculate the surface area of revolution about y, you can use the formula: S = ∫2πy√(1 + (dy/dx)^2)dx, where y is the function of the curve and dx is the differential element. This integral can be evaluated using integration techniques such as integration by parts or substitution.
What is the difference between surface area of revolution about x and y?
The surface area of revolution about x and y differ in the axis of revolution. When calculating the surface area of revolution about x, the curve is rotated around the x-axis, while for y, the curve is rotated around the y-axis.
What types of curves can be used to calculate surface area of revolution about y?
Any 2-dimensional curve can be used to calculate surface area of revolution about y, as long as it is rotated 360 degrees around the y-axis. This includes curves such as circles, parabolas, and hyperbolas.
Why is calculating surface area of revolution about y important in science?
The surface area of revolution about y is important in science because it allows us to find the total area of irregular 3-dimensional shapes, which is crucial in understanding properties such as volume, density, and surface tension. It is also used in a variety of fields, such as physics, engineering, and architecture.
