Surface charge density on a cylindrical cavity
In summary, the conversation discusses a problem involving a line charge inside a cylindrical cavity and the determination of the surface charge density on the inside wall of the cavity. The solution involves using the potential as a Fourier cosine series and setting it to zero at the surface of the cavity to find the coefficients. The use of image charges is also mentioned, but the location of the charges is uncertain. The potential inside the cylinder must have non-negative values and no logarithmic terms.
rockbreaker
Hi folks, I am having trouble generalizing a well-known problem. Let's say we have a cylindrical cavity inside a conductor, and in this cavity runs a line charge λ. I would now like to know the surface charge density on the inside wall of the cavity, but with the line charge not in the center of the cylindrical cavity.
It's clear that if the line charge is located in the center, the surface charge density is a constant because all points of the inner surface of the cavity are equally close to the line charge.
So when the line charge is off-center, the surface charge distribution has to be varying around the center with the angle. Yet, the inner surface of the cavity still has to be a equipotential surface.
Can anyone help me with an idea of how to solve this problem? I will for sure need the cosine law to determine the distance of the surface of the cavity from the line charge, but from there...?
Thank you very much for your help!
Regards, John
Write the potential as a Fourier cosine series in a_n r^n cos\theta
plus ln[\sqrt{r^2+d^2-2rd cos\theta}].
Expand the log in a Fourier cosine series . Then set the potential = 0 at the surface r=R, setting each term in the series to zero to find the coefficients a_n.
That's a great idea, thank you very much. I first tried to solve this problem with image charges, but the problem is that I don't know where to place it. In the solution of Laplace's equation, all coeficients for any term r^n for n<0 must be zero, but can there survive any others than the logarithmic term?
(Two line charges a distance L/2 apart produce a potential λ/2∏ε0*ln((r^2+(L/2)^2-rLcosθ)/(r^2+(L/2)^2+rLcosθ)).)
Inside the cylinder, n must be zero or positive, with non negative and no log.
Hello John,
Thank you for reaching out for assistance with your problem. The surface charge density on the inside wall of a cylindrical cavity with an off-center line charge can be determined by using the concept of Gauss's law and the superposition principle.
First, let's consider the case where the line charge is located at the center of the cylindrical cavity. In this case, as you mentioned, the surface charge density is constant because all points on the inner surface of the cavity are equidistant from the line charge. This can be calculated using the equation σ = λ/2πr, where σ is the surface charge density, λ is the line charge, and r is the radius of the cavity.
Now, for the off-center case, we can use the superposition principle to determine the surface charge density. This principle states that the total electric field at a point is the vector sum of the individual electric fields from each charge present. In this case, we can consider the off-center line charge as two separate line charges, one located at the center and the other located at the off-center position. Using this concept, we can calculate the electric field at a point on the inner surface of the cavity due to the off-center line charge, and then subtract the electric field at the same point due to the line charge at the center.
Once we have the electric field at a point on the inner surface of the cavity, we can use Gauss's law to calculate the surface charge density. This law states that the electric flux through a closed surface is equal to the charge enclosed divided by the permittivity of the medium. In this case, the closed surface would be the inner surface of the cavity and the charge enclosed would be the total charge of the off-center line charge.
Using these principles, we can determine the varying surface charge density on the inside wall of the cylindrical cavity. I hope this helps and good luck with your problem.
Best,
Related to Surface charge density on a cylindrical cavity
1. What is surface charge density on a cylindrical cavity?
Surface charge density on a cylindrical cavity is the measure of electric charge per unit area on the surface of a cylindrical cavity. It is denoted by the symbol σ and is expressed in units of Coulombs per square meter (C/m^2).
2. How is surface charge density calculated on a cylindrical cavity?
Surface charge density on a cylindrical cavity can be calculated by dividing the total charge on the surface of the cavity by the surface area of the cylinder. This can be represented by the equation σ = Q/A, where Q is the total charge and A is the surface area of the cylinder.
3. What factors affect the surface charge density on a cylindrical cavity?
The surface charge density on a cylindrical cavity is affected by the radius of the cylinder, the total charge on the surface, and the dielectric constant of the material surrounding the cavity. It is also affected by the presence of any external electric fields.
4. What is the significance of surface charge density on a cylindrical cavity?
The surface charge density on a cylindrical cavity is important in determining the electric field within and around the cavity. It also plays a role in the overall capacitance of the cylindrical cavity, which is a measure of its ability to store electric charge.
5. How does surface charge density on a cylindrical cavity relate to other electrical properties?
Surface charge density on a cylindrical cavity is related to other electrical properties such as electric potential, electric field, and capacitance. It is also related to the distribution of charge within the cavity and the overall electric flux through the surface of the cavity.
