Surface integral and divergence theorem over a hemisphere
In summary, the conversation discusses how to evaluate the integral \oint d\vec{A}\cdot\vec{v} over a hemisphere in spherical coordinates, both directly by surface integration and using the divergence theorem. The surface area element and volume element in spherical coordinates are also mentioned, as well as the importance of carefully considering the angles in the integrand. The suggestion to use the divergence theorem is discussed, with the reminder to be cautious of jumping over the integral.
marineric
Please evaluate the integral [itex]\oint[/itex] d[itex]\vec{A}[/itex][itex]\cdot[/itex][itex]\vec{v}[/itex], where [itex]\vec{v}[/itex] = 3[itex]\vec{r}[/itex] and S is a hemisphere defined by |[itex]\vec{r}[/itex]| [itex]\leq[/itex]a and z ≥ 0,
a) directly by surface integration.
b) using the divergence theorem.
-Divergence theorem in spherical coordinates
Another one where the [itex]\vec{r}[/itex] messes me up. Simple enough if it was in regular xyz. Plus the [itex]\vec{v}[/itex]... and I don't really know where to start.
Well, [itex] \mathbf{r} = x \mathbf{e}_x + y \mathbf{e}_y + z \mathbf{e}_z [/itex] shouldn't be too confusing...
In this case, the shape of the integration area suggests that you might want to use spherical coordinates instead of x, y and z. Do you know what the area element is in spherical coordinates? (or even better, can you calculate it?) What about volume element?
Ok so attempt at a solution:
∫∫ 3[itex]\vec{r}[/itex] r[itex]^{2}[/itex]sinθdθd[itex]\phi[/itex]
limits are 0 to 2∏ for θ, and 0 to ∏/2 for [itex]\phi[/itex], or I could just do 3r^3 time the surface area of a hemisphere, which is 2*∏*r^2, so, 6*∏*a^5?
for divergence... do I just take the divergence in spherical coordinates and multiply by the volume of a hemisphere, which is 2/3*∏*r^3?
Okay, couple of things
1) The surface area element is a vector.
2) Be careful with the angles. Right now your definitions do not work.
3) As you noticed, the integrand does not depend on the angles. Be careful about jumping over the integral though; now you're getting too many factors of r.
Is the divergence constant? If it is, then it should of course work.
Related to Surface integral and divergence theorem over a hemisphere
What is a surface integral?
A surface integral is a mathematical concept that involves calculating the total value of a function over the surface of a given shape. It is similar to a regular integral, but instead of integrating over a one-dimensional interval, it integrates over a two-dimensional surface.
What is a hemisphere?
A hemisphere is a three-dimensional shape that is half of a sphere. It is a curved surface that is bounded by a circular base and a curved surface that meets at the apex.
What is the divergence theorem?
The divergence theorem, also known as Gauss's theorem, is a mathematical theorem that relates the surface integral of a vector field over a closed surface to the volume integral of the divergence of the same vector field over the enclosed volume. In other words, it states that the flux of a vector field through a closed surface is equal to the volume of the vector field's sources and sinks within the enclosed volume.
What is the surface integral over a hemisphere?
The surface integral over a hemisphere is the calculation of the total value of a function over the surface of a hemisphere. This involves finding the double integral of the function over the curved surface of the hemisphere. It can also be calculated using the divergence theorem by finding the volume integral of the function's divergence over the enclosed volume of the hemisphere.
What are some real-world applications of surface integrals and the divergence theorem over a hemisphere?
Surface integrals and the divergence theorem have various real-world applications, including in physics, engineering, and computer graphics. For example, they can be used to calculate the flux of a fluid through a curved surface, the electric field around a charged object, and the heat flow through a solid object. In computer graphics, they can be used to calculate the lighting and shading effects on curved surfaces.
