Incand
- 334
- 47
Calculate the integral ##\oint_C \vec F \cdot d\vec S##, where ##C## is the closed curve constructed by the intersection of the surfaces ##z = \frac{x^2+y^2}{4a}## and ##x^2+y^2+z^2=9a^2##, and ##\vec F## is the field ##\vec F = F_0\left( \frac{a}{\rho}+\frac{\rho^2}{a^2} \right)\hat \phi##. (##a## and ##F_0## are constants.)
(I'm guessing this fits better here than in the calculus forum since since the question is as preparation for EM-class)
Line current with strength ##J##
##\vec F = \frac{J}{2\pi \rho} \hat \phi##.
We see the first part of the force is a line current with strength ##2\pi F_0a## so it's total contribution to the integral over a closed loop is ##2\pi F_0a##.
I'm left with ##\vec F_2 = F_0\frac{\rho^2}{a^2}\hat \phi##. We note from ##z=\frac{x^2+y^2}{4a}## that if ##a >0## ##z## has to be strictly positive and if ##a < 0## ##z## is strictly negative.
Substituting into the second equation we have
##(z+2a)^2-4a^2 = 9a^2 \Longrightarrow z=(\pm \sqrt{13} -2)a##. We conclude that ##z## is constant and since ##\rho^2 = x^2+y^2##, ##\rho## is also constant.
Calculating the curl we get ##\nabla \times \vec F_2 = \frac{3F_0}{a^2}\rho \hat z##.
Using stokes theorem and since we know ##\rho## is constant and using ##\hat z## as the normal vector
##\int_C \vec F_2 \cdot d\vec r = \frac{3F_0}{a^2}\rho \int_S dS = \frac{3\pi F_0}{a^2}\rho^3 ##
Let's assume that ##a>0## we then have that ##\rho = 2a\sqrt{\sqrt{13}-2}##. Using this we have
##\int_C \vec F_2\cdot \vec r = 24\pi F_0a\left( \sqrt{13}-2 \right)^{3/2}##.
So the total value of integral should be
##2\pi F_0a\left(12(\sqrt{13}-2)^{3/2}+1\right)##.Another approach would be to use the line element ##d\vec r = d\rho \hat \rho + \rho d\phi \hat \phi + dz \hat z##
##\int_C \vec F_2 \cdot d\vec r = \int_C \frac{F_0\rho^3}{a^2}d\phi## And everything inside should be a constant. Since both ##z## and ##\rho## are constant we should be on a circle that's parallel to the ##xy##-plane and we should integrate from ##\phi =0 \to \phi = 2\pi##. So the integral becomes
##\int_C \vec F_2 \cdot d\vec r = \frac{2\pi F_0 \rho^3}{a^2} = 8\pi aF_0(\sqrt{13}-2)^{3/2}##. Giving us the value
##2\pi F_0a\left(8(\sqrt{13}-2)^{3/2}+1\right)##.
According to the answer the second approach gave me the right answer and the first one is wrong but I can't see where I go wrong?
