Surface of Water in a Rotating Bucket via Calc. of Variations
In summary, the conversation discusses the concept of "Newton's bucket" - a rotating hollow cylinder filled with water that results in a parabolic surface. The possibility of using calculus of variations to solve for the surface function is considered, but it is determined that extremizing the action, rather than total energy, would be a more appropriate method. The concept of a fictitious force and potential is mentioned, and it is noted that the constraint of the total amount of water must also be taken into account through the use of a Lagrange multiplier.
MisterX
764
71
I am referring to "Newton's bucket" -- essentially a hollow cylinder filled with water inside which rotates about the cylinder's axis. The result is that the surface of the water is a parabola. The argument for this is that the surface normal of the water must be directly opposing the other forces at the surface. This is fine.
However, I am wondering if such a problem can be approached with calculus of variations to solve for a function describing the surface.
The problem I ran into, when naively trying to do it this way, is that the energy will of course be minimum when the height of the water is minimum, leading to obtaining no stationary solution, and the useless conclusion that the energy is reduced when the total amount of water is reduced. So, I want only want to consider variations of the height function that satisfy and additional constraint that the total amount of water is the same.
hmm. I think you'll have more success in extremizing the action of the system, i.e. the kinetic energy minus the potential energy. But yes, you'll still need to use the constraint for the total amount of water. I'm pretty sure that trying to minimise the total energy (even while using the constraint) will not work. If you think about it for a bit, we know that what happens is that the water surface takes a parabola shape, with the water curving upwards at the edge of the bucket. But also, the water is moving faster at the edge of the bucket. In other words, the curve is such that there is more fast moving water than there would have been with a flat horizontal curve. So energy is not minimised by the choice of curve. Also, we know that energy is not maximised because that would simply be a curve that goes up very sharply near the edge of the bucket. So I think you need to extremise the action, not the energy.
I was working in the rotating frame, where the water was assumed to be stationary. Sorry if that was not clear. Does it make sense then?
oh, ok. yeah, that would work too. But it is a bit less intuitive, in my opinion. You would need to introduce a fictitious force, and from that, you can calculate a 'fictitious potential' (I'm not even sure if that is the proper terminology, which is why I've put scare quotes around it). And from there, you can add this to the potential due to gravitational field. Also, since there is zero kinetic energy in the rotating frame, this means Extremizing the action is essentially the same as extremizing the total energy (since there is only potential energy). So anyway, if you extremize the potential energy, you should get the correct answer for the shape of the surface of the water.
edit: also, you still need to include the constraint of the volume of water, which you can do by introducing a Lagrange multiplier. so you should have something like:
[tex]\int \left( \text{P.E. per volume} + \lambda \right) \ dV[/tex]
and you should then extremize this expression with respect to the function ##z(r)##.
I find this question and approach to be very interesting. Using calculus of variations to solve for the surface of water in a rotating bucket is a creative and potentially useful application of this mathematical tool.
To address the issue of obtaining a minimum energy solution when the height of the water is minimum, it is important to consider the physical constraints and boundary conditions of the problem. In this case, the total amount of water in the bucket must remain constant, so this should be incorporated into the variation of the height function. Additionally, the surface of the water must remain smooth and continuous, which can also be included in the variation.
By incorporating these constraints and boundary conditions into the variation, it is possible to obtain a more meaningful and physically realistic solution for the surface of the water. This approach may require some additional mathematical techniques, but it is certainly worth exploring as it could provide valuable insights into the behavior of rotating bodies of water.
Overall, I believe that using calculus of variations to solve for the surface of water in a rotating bucket is a promising direction for further research and could potentially lead to new understandings and applications in fluid dynamics.
Related to Surface of Water in a Rotating Bucket via Calc. of Variations
1. What is the "Surface of Water in a Rotating Bucket via Calc. of Variations" problem?
The "Surface of Water in a Rotating Bucket via Calc. of Variations" problem is a mathematical and physical problem that seeks to find the shape of the water surface in a rotating bucket. This problem arises in the study of fluid mechanics and is often used to demonstrate the application of the calculus of variations.
2. Why is this problem important?
This problem is important because it helps us understand the behavior of fluids in a rotating frame of reference. It also has practical applications, such as in the design of centrifuges and other rotating devices.
3. How is the problem solved using the calculus of variations?
The problem is solved by minimizing the total potential energy of the system, which includes the energy due to gravity and the centrifugal force. This is done by applying the Euler-Lagrange equation, which yields the shape of the water surface as a function of the angular velocity of the bucket.
4. What are the assumptions made in this problem?
The problem assumes that the water is incompressible and inviscid, and that the surface tension effects can be neglected. It also assumes that the water surface is in equilibrium and that the bucket is rotating at a constant angular velocity.
5. How does the shape of the water surface change with different angular velocities of the bucket?
The shape of the water surface changes as the angular velocity of the bucket increases. At low angular velocities, the surface is flat, but as the angular velocity increases, the surface becomes concave and eventually forms a paraboloid shape. At even higher angular velocities, the surface becomes convex and forms a hyperboloid shape.
17K
  • Mechanics
  • Classical Physics
