MHB Surjectivity of a Free Module Homomorphism implies injectivity
  • Thread starter Thread starter caffeinemachine
    module
caffeinemachine
MHB
I am trying to prove the following:Let $R$ be a commutative ring and $M$ be a free $R$-module having a finite basis of $n$ elements.
Let $T:M\to M$ be a surjective $R$-module homomorphism.
Then $T$ is injective.Let $I$ be a maximal ideal of $R$.
Note that $I$ annihilates $\widehat M:=M/IM$ and thus $\widehat M$ is an $\bar (R/I)$-module.
Write $\bar R=R/I$.For each $r\in R$, write $\bar r$ to denote $r+I$ and for each $m\in M$ write $\widehat m$ to denote $m+IM$.Define $\widetilde T:\widehat M\to \widehat M$ as
$$\widetilde T(\widehat m)=\widehat{Tm},\quad \forall \widehat m\in \widehat M$$
It is easy to see that $\widetilde T$ is well defined.
Note that $\widetilde T$ is a surjective linear operator on a vector space and hence is also injective.Note that if $\mathcal B=\{e_1,\ldots,e_n\}$ is a basis of $M$, then $\widehat B=\{\widehat e_1,\ldots,\widehat e_n\}$ is a basis for $\widehat M$.Now suppose $T(r_1e_1+\cdots+r_ne_n)=0$. Then we get $\widetilde T(\bar r_1\widehat e_1+\cdots+\bar r_n\widehat e_n)=\widehat 0$.
Since $\widetilde T$ is injective, we get $\bar r_i=\bar 0$ for all $i$.
But this doesn't lead to $r_i=0$.Can anybody see how to complete the proof from here?
Hi caffeinemachine,
Let's start from the beginning, with your basis $\mathcal{B} = \{e_1,e_2,\ldots, e_n\}$. There are unique $R$ - scalars $a_{ij}$ ($i,j = 1,2,\ldots, n$) such that
$$ T(e_i) = \sum_{j = 1}^n a_{ij}e_j.$$
Since $T$ is surjective, there exist $R$-scalars $b_{ki}$ ($i, k = 1, 2,\ldots, n$) such that
$$e_k = T\Bigl(\sum_{i = 1}^n b_{ki} e_i\Bigr).$$
Hence, for all $k$,
$$e_k = \sum_{i = 1}^n b_{ki} T(e_i) = \sum_{i = 1}^n \sum_{j = 1}^n b_{ki}a_{ij} e_j = \sum_{j = 1}^n c_{kj} e_j,$$
where the constants $c_{kj}$ are defined by the equation
$$ c_{kj} = \sum_{i = 1}^n b_{ki}a_{ij}.$$
Since $\mathcal{B}$ is an $R$-basis for $M$, it follows that $c_{kj} = \delta_{kj}$, i.e.,
$$(*)\quad \sum_{i = 1}^n b_{ki}a_{ij} = \delta_{kj} \quad (k, j = 1, 2,\ldots, n)$$
Use the orthogonality relations $(*)$ to show that $T$ is injective.
Euge said:
Hi caffeinemachine,
Hence, for all $k$,
Hey Euge!
What you have done is absolutely correct and I thank you for helping out.
But the thing is, the equation $(*)$ is where I had started.
I am a beginner in module theory and yesterday I learned the fact that if $A$ and $B$ are square matrices with entries from a commutative ring $R$, then $AB=I$ if and only if $BA=I$.
If I use this fact then the equation $(*)$ does my job and solves the question I posted.
But the proof of the above which I know uses determinants quite extensively.
I do not want to use determinants.
This may seem unreasonable. But I think determinant-free proofs are much more elegant and enlightening.
So I was trying to prove that if you have a commutative ring $R$, and $R$-linear maps $T,S:R^n\to R^n$ such that $TS=\text{id}$, then $ST=\text{id}$.
From here it was a natural question that if $T:R^n\to R^n$ is surjective then it is also injective.
A determinant-free proof of this in the case where $R$ is a field is well-known. It uses rank-nullity theorem.
I doubt if there is an analog of the rank nullity theorem in the context of free modules of finite rank over a commutative ring without imposing some extra condition on the ring.
You do not need determinants to prove either injectivity of $T$ using $(*)$, or the statement $AB = I$ if and only if $BA = I$.
There are different, non-determinantal methods to prove injectivity of $T$. One way is to define a map $S : M \to M$ by the equation
$$S\Bigl(\sum_{i = 1}^n x_i e_i\Bigr) = \sum_{i = 1}^n \sum_{k = 1}^n x_k b_{ki}e_i$$
and show that $ST(e_i) = e_i$ for all $i$.
To show that $AB = I$ if and only if $BA = I$, first suppose $AB = I$. We want to show that $A$ is invertible. Suppose $A$ is not invertible. Then there is a sequence $\{E_i\}_{i = 1}^r$ of elementary matrices such that $E_1 E_2\cdots E_r A$ has a row of zeros. Then $E_1 E_2\cdots E_r AB$ has a row of zeros. Since $AB = I$, we deduce that the invertible matrix $E_1 E_2 \cdots E_r$ has a row of zeros, a contradiction. Therefore $BA = I$. A symmetric argument proves the converse.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
