MHB Sustainability of pyramid scheme
  • Thread starter Thread starter Ken Somerville
    Pyramid
The discussion focuses on the sustainability of a new affiliate program structured as a pyramid scheme, which is legal and involves a product and merchant accounts. It features a 2x2 forced rotator matrix with automatic re-entry at each level, requiring a $300 buy-in for each of the seven positions on the board. As participants cycle through the levels, the apex position re-enters the system, generating continuous profits and potential rapid turnover. Concerns are raised about the long-term viability of this model and when it might fail. The conversation seeks insights into the mathematical aspects of this scheme's sustainability.
Ken Somerville
I’m about to get involved with a new affiliate program,
before I market this I want to know that it is going to work.
Pyramid (yes, it is legal; there is a product,
merchant accounts used, taxes will have to be paid).
2x2 Forced Rotator Matrix with an Automatic Re-Entry at each level.
7 Positions on Board (only four available to be filled at a one time buy-in of \$300.00 ea).
As the #1 (apex) position leaves that board, they will be re-entered back onto Level 1 board for \$300.00 (taken out of the profits earned), it now looks for its’ sponsor, realigns itself again on its’ sponsor’s board, and continues to repeat the process over and over again to infinity.
As the process speeds up, and moves from daily to hourly, by minutes, by seconds, etc. Is this sustainable? At what point would this falter, or does it?
O Pay position \$1200.00-\$300. (auto re-buy done by computer).
O O Middle positions
O O O O Bottom positions to fill at \$300.00 ea
Thanks for your help. Ken
Mathematics news on Phys.org
Re: Hello! I need help with a mathematical query. Please and Thank You
Hello and welcome to MHB, Ken. :D
I have moved your topic to our Business Mathematics sub-forum, as it seems to be a better fit than Analysis.
Typically, responses are posted within a topic, not emailed, and so I have removed your email address from public view just so that it does not potentially fall into the wrong hands.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
