Susy introduction paper superspace
In summary, the Coleman-Mandula theorem states that there cannot be any symmetry that is linked with the Poincare-group in a nontrivial way. The Haag-Lopuszanski-Sohnius-Theorem provides a solution to this by showing that the anticommutation relation of the charge Q with itself can only be proportional to 4-momentum. This explains the building of a superspace and can be further explored in Weinberg Vol 3.
Barmecides
80
Hello,
I have read in a susy introduction paper that if we call Q the charge which links fermions and bosons, then we have the following anticommutation relation :
{Q_a, Q_b} = 2 sigma_ab P
where P is 4-momentum.
So, is this relation only due to Coleman-Mandula theorem which force the result of the anticommutation relation to be P ? Or is there any other deeper reason ?
Because it seems this is this relation which explains the building of a superspace.
Greetings,
Actually Coleman-Mandula says that there can't be any symmetry linked in a nontrivial way with the Poincare-group. The way around is the Haag-Lopuszanski-Sohnius-Theorem (the second name may be misspelled). If you want a proof for this theorem, try Weinberg Vol 3.
The basic idea is that there are no other operators transforming the way Q_a Q_b has to, so the anticommutator can only be proportional to P.
Eisenhorn.
Hello,
Thank you for bringing up this interesting topic. The anticommutation relation you mentioned is indeed a fundamental aspect of supersymmetry (SUSY) and is known as the SUSY algebra. It is a result of the Coleman-Mandula theorem, which states that in a theory with both bosonic and fermionic symmetries, the only possible way for them to coexist is through a direct product, as seen in the SUSY algebra.
However, there are also deeper reasons for this relation, which are rooted in the concept of superspace. Superspace is a mathematical framework that extends the traditional spacetime to include both bosonic and fermionic coordinates, allowing for the unification of bosonic and fermionic fields in a single description. The SUSY algebra arises naturally in this framework as a consequence of the Grassmann nature of the fermionic coordinates.
Furthermore, the SUSY algebra is a crucial component in the construction of supersymmetric theories, as it allows for the cancellation of divergences that would otherwise plague these theories. This is known as the "supersymmetry miracle" and is a powerful tool in addressing the hierarchy problem in particle physics.
In summary, while the anticommutation relation in the SUSY algebra is a result of the Coleman-Mandula theorem, it also has deep connections to the concept of superspace and plays a crucial role in the construction and understanding of supersymmetric theories. I hope this helps clarify the link between the SUSY algebra and superspace.
Related to Susy introduction paper superspace
1. What is superspace in the context of Susy introduction paper?
Superspace is a mathematical framework used to describe supersymmetric theories, which are extensions of the standard model of particle physics that incorporate the concept of supersymmetry. In the context of Susy introduction paper, superspace is used to describe the superpartners of known particles and their interactions.
2. Why is supersymmetry important in particle physics?
Supersymmetry is important in particle physics because it helps to solve some of the open questions and limitations of the standard model, such as the hierarchy problem and the lack of a candidate for dark matter. It also allows for unification of the fundamental forces of nature and provides a more elegant mathematical description of the universe.
3. What is the role of superspace in the development of supersymmetric theories?
Superspace is a crucial tool in the development of supersymmetric theories because it allows for the incorporation of supersymmetry into the mathematical framework of quantum field theory. This makes it easier to describe and analyze the interactions between particles and their superpartners.
4. How does the concept of superspace relate to the concept of extra dimensions?
Superspace is often used in theories with extra dimensions because it allows for the description of supersymmetric theories in higher dimensions. In this context, superspace is extended to include extra dimensions, allowing for the inclusion of additional particles and interactions that are not present in our 3+1 dimensional world.
5. What are the implications of superspace for experimental research?
The use of superspace in describing supersymmetric theories has important implications for experimental research, as it allows for the prediction of new particles and interactions that can be tested at high energy particle colliders. It also provides a theoretical framework for understanding the behavior of these particles and their interactions with known particles.
