Suvat - Ball thrown off a roof
  • Thread starter madmike159
  • Tags
    Ball Suvat
In summary, to solve this problem, you can use the equation for displacement (y) in terms of time (t) with the given data to find the initial velocity (vi). Then, use the equation for velocity (v) to find the maximum height and final velocity of the ball.
madmike159
A ball is thrown vertically upwards from a roof of a building and it lands 3 seconds later on the ground 7 meters below the roof. Calculate:
a) the speed with which the ball was thrown upwards
b) the maximum height of the ball above the ground
c) the speed with which the ball hits the ground
v = u + at
s = ut + (1/2)(a)(t^2)
s = vt - (1/2)(a)(t^2)
v^2 = u^2 + 2as
s = ((u + v)/2)t
I was trying to help a friend with this problem. I have tried breaking it down to 3 sections, up, down to starting height and down to the ground; but there never seems to be enough information to solve anything. I can't tell if I am missing something obvious or something was left out of the question in the book.
Up
s = ? u = ? v = 0m/s a = -9.8m/s^2 t = ?
Down
s = ? u = 0 v = ? a = -9.8m/s^2 t = ?
To Ground
s = 7 u = ? v = ? a = -9.8m/s^2 t = ?
Nothing was left out of the question in the book; the problem is quite solvable. Your breaking of the problem into three parts is a step in the right direction. Try thinking about this: If you throw a ball upwards, what must be its velocity when it comes back down to the height from which it was thrown upwards? What is the ball's velocity at its maximum height? How can you express the time it takes the ball to reach its maximum height in terms of its initial velocity and the constant acceleration it undergoes due to gravity?
Just realized why some people call the equations for one dimensional motion with constant acceleration suvat.
The solution is much simpler if you use displacement (y) in terms of the time. Deciding "up" positive, the initial velocity vi is positive, the acceleration is a= -g, and the final displacement is yf= -7m. No need to break the problem.
The equation for the displacement y=vit-g/2 t2 is valid for the whole motion. Substitute the given data for the final time and displacement, you get the initial velocity.
After that, you can use the equation for velocity v = vi - gt, to find out the maximum height and the final velocity.
Likes AlephNumbers
Related to Suvat - Ball thrown off a roof
1. What is the meaning of "Suvat" in the context of a ball thrown off a roof?
"Suvat" is a term used in physics to represent the initial conditions of an object's motion. It is an acronym for the variables: displacement (s), initial velocity (u), final velocity (v), acceleration (a), and time (t). In the context of a ball thrown off a roof, these variables are used to calculate the ball's position, velocity, and acceleration at any given time.
2. How is the displacement (s) calculated for a ball thrown off a roof?
The displacement (s) of a ball thrown off a roof can be calculated using the equation s = ut + ½at², where u is the initial velocity, a is the acceleration due to gravity (-9.8 m/s²), and t is the time elapsed. This equation assumes that the ball is thrown straight up or down, and does not take into account air resistance.
3. What is the significance of initial velocity (u) in a ball thrown off a roof?
The initial velocity (u) represents the speed and direction at which the ball is thrown off the roof. This variable is important because it affects the ball's trajectory and determines how far it will travel before hitting the ground.
4. How does acceleration (a) affect the motion of a ball thrown off a roof?
The acceleration (a) due to gravity (-9.8 m/s²) affects the ball's motion by constantly pulling it towards the ground. This acceleration remains constant throughout the ball's flight, causing it to increase in speed as it falls towards the ground. The direction of the acceleration is always downwards, towards the center of the Earth.
5. Can the time (t) variable be negative when calculating the motion of a ball thrown off a roof?
No, the time (t) variable cannot be negative when calculating the motion of a ball thrown off a roof. This is because time is measured in seconds, and it cannot have a negative value. However, the time can be represented as a negative value when calculating the displacement (s) if the ball is thrown downward, as the displacement in this case would be decreasing instead of increasing.
