MHB SW1986's question at Yahoo Answers regarding a solid of revolution
  • Thread starter Thread starter MarkFL
    Revolution Solid
The discussion revolves around calculating the volume of a solid of revolution defined by the function y=(x^3)-(x^5) between x=0 and x=1, revolving around the line x=3. The shell method is suggested for finding the volume, with the volume element expressed as dV=2π(3-x)(x^3-x^5)dx. After integrating, the volume is calculated to be V=27π/70. The washer method is deemed impractical due to difficulties in expressing y in terms of x. The response encourages further calculus inquiries in the forum for additional assistance.
MarkFL
MHB
Here is the question:
Volume of a solid of revolution about x=3?
What is the volume of the solid of revolution bounded by
y=(x^3)-(x^5)
y=0
x=0
x=1
I have been using the shell method and I keep getting a negative answer which is obviously incorrect. (I keep getting 2pi(-14183/140). I'm trying to get the integral set up to use the washer method but I am having a very hard time integrating with respect to y instead of x. For example, I don't know how to express y=x^3-x^5 in terms of y. Help?
Here is a link to the question:
Volume of a solid of revolution about x=3? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Re: SW1986's question at Yahoo! Answers regarding a sold of revolution
Hello SW1986,
The first thing I like to do is plot the region to be revolved:
https://www.physicsforums.com/attachments/806._xfImport
Using the shell method, we may first compute the volume of an arbitrary shell:
$$dV=2\pi rh\,dx$$
where:
$$r=3-x$$
$$h=x^3-x^5$$
and so we have:
$$dV=2\pi (3-x)\left(x^3-x^5 \right)\,dx=2\pi\left(x^6-3x^5-x^4+3x^3 \right)\,dx$$
Summing the shells by integration, we then find:
$$V=2\pi\int_0^1 x^6-3x^5-x^4+3x^3\,dx=2\pi\left[\frac{x^7}{7}-\frac{x^6}{2}-\frac{x^5}{5}+\frac{3x^4}{4} \right]_0^1=2\pi\left(\frac{1}{7}-\frac{1}{2}-\frac{1}{5}+\frac{3}{4} \right)=\frac{27\pi}{70}$$
In this case, since we cannot explicitly solve the given function for $x$, using the washer method is impractical.
To SW1986 and any other guests viewing this topic, I invite and encourage you to post other calculus questions here in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
