Wisp100
- 1
Hi,
I was going through the web and was reading about this swap, however I want to make sure on a few questions I still have and was told I could get good advise in these forums.
So I was going to go ahead and change a switch for a power outlet for convenience, but then realized it might not be very safe to load it with a power outlet, depending on the circuit the switch is installed to. I am intending to connect a monitor here, the monitor specs say it has a 33Watt consumption.
There are 2 switches that can operate the ceiling's light bulb in the room, one of the switches is the one I want to replace with a power outlet. I opened up the switch box and I have 3 cables there, a black one, a red one and a white one. I believe the black one and the red one are the phase cables and the white one is the neutral.
So I have these questions:
- Is it possible and safe to make this swap?
- If the safety is questionable, I would have to measure the current present there to make sure? What reading range would I need to have to determine it is indeed safe?
- If done, will I have to have the remaining switch ON to be able to power the new outlet?
Thanks so much in advanced for any help I can get on this. :)
