Switching the links in a linked list
  • Python
  • Thread starter FallenApple
  • Tags
    Links List
In summary, the individual was attempting to alter a linked list in a systematic way by interchanging pointers. However, for some reason, the alterations did not work. The solution is to avoid using any links that have been changed and to be careful with pointer manipulation to avoid orphaned nodes and memory leaks. Additionally, implementing the list as a doubly linked list and testing for null pointers can also help prevent errors.
FallenApple
566
61
So I have a linked list a->b->c->d
and I want to make another list
b->a->d->c
in a systematic way by interchanging pointers. But for some reason it isn't working. All I did was move the link between b and c into b to a. Then the link from a to b, changed to a to d. Then the one connecting c to d is reversed. I'm not sure what went wrong.
Python:
class ListNode(object):
    def __init__(self, x):
        self.val = x
        self.next = None
A=['a','b','c','d']
head=ListNode(A[0])
#filling the linked list with abcd
temp=head
for i in A[1:]:
  temp.next=ListNode(i)
  temp=temp.next
point=head
print("the current linked list")
while(point):
  print(point.val)
  point=point.next
print("   ")
#attempting to alter the list
Temp1=head.next.next
head.next.next=head    # moving the link between b-c to a
Temp2=head.next
head.next=head.next.next.next  #moving the link between a-b to d
head.next.next.next=Temp1    #moving the link between d and c
head=Temp2
#print(head)
print("the new linkedlist")
point=head
while(point):
  print(point.val)
  point=point.next
The output is
a
b
c
d
the new linkedlist
b
a
c
d
Technology news on Phys.org
You have to avoid using any links that you've changed, either with careful ordering of operations and/or using temp pointers to avoid conflicts.
For example, if swapping two nodes in a linked list, if the nodes are adjacent, the next pointers are effectively rotated, but if the nodes are not adjacent, then two pairs of next pointers are swapped. This can be handled with common code by first swapping the external pointers to the two nodes, followed by swapping the nodes internal next pointers.
Given a list a->b->c->d->e->f, to swap b and e, swap(a->next, d->next), swap(b->next, e->next). To swap c and d, swap(b->next, c->next), swap(c->next, d->next).
Likes FallenApple
Implement as a doubly linked list. In that data structure any given node knows who's it is attached to. Be very careful with the pointer manipulation or orphaned nodes (and thus memory leaks) will occur
Likes FallenApple
Also make sure to test the link pointers for null so that the node is valid. Usually the "next" pointer is null to indicate there are no further nodes
Related to Switching the links in a linked list
1. How does switching the links in a linked list work?
Switching the links in a linked list involves changing the pointers that connect the nodes in the list. This allows for rearranging the order of the nodes without actually moving the data within them.
2. Why would you want to switch the links in a linked list?
Switching the links in a linked list can be useful for sorting the data within the list or for implementing algorithms that require a specific order of nodes. It can also improve the efficiency of certain operations on the list.
3. Is it possible to switch the links in a circular linked list?
Yes, it is possible to switch the links in a circular linked list. However, this requires special consideration as the last node in the list will point back to the first node and the first node will need to be updated to point to the new first node after the switch.
4. What is the time complexity of switching the links in a linked list?
The time complexity of switching the links in a linked list is O(1) or constant time. This is because the operation only involves changing the pointers and does not require traversing the entire list.
5. Are there any potential issues to be aware of when switching the links in a linked list?
One potential issue to be aware of is ensuring that the links are switched correctly to avoid creating a loop or breaking the list. It is also important to consider the order of operations when switching links to avoid losing any data in the process.
