I Symbol for matrix representative of a tensor
doktorglas
TL;DR Summary
Searching for a symbol to be used instead of "equals" between a tensor and a matrix.
Hi,
I'm simply searching for some standard symbol (in place of an equals sign) to indicate that a matrix is a representative of a tensor in some given basis. Is there any standardized symbol like this, or how is this usually written in literature?
E.g. say we have a O(1,1) metric tensor gμν which can be represented in matrix form as diag(1,-1) or, in another basis, as off-diag(1,1), I would not want to write gμν = diag(1,-1), since the matrix is not the tensor but merely represents the tensor in the specific basis in question. Even though I suppose that it is indeed often written like this, it appears to be an abuse of notation.
Many thanks in advance
You will have to explain it anyway, so you can take whatever you want. Here are some examples I would choose from:
\triangleq \, \qquad \,\stackrel{1:1}{\longleftrightarrow}\, \qquad \,\circeq\, \qquad \,\bumpeq\, \qquad \,\backsimeq\, \qquad \,\sim\, \qquad \,\fallingdotseq
Another possibility is writing the tensor consequently as ##\sum u_\rho \otimes v_\rho ## without defining a basis for ##u_\rho ,v_\rho ## and use matrices only after choosing a basis.
Great reply, thank you! I was actually thinking something like an equals sign with a dot above, so I might have seen this somewhere.
Just out of curiosity: Could you point to any references where some of these various alternatives are used? Particularly the ##\stackrel{1:1}{\longleftrightarrow}##. What would be the significance of the "1:1" there?
Not without searching for them. Authors are usually far less cautious and do not distinguish between vectors and their coordinates or assume that the basis is clear. Many of the threads in the linear algebra forum are based on this negligence, especially if more than one basis are involved.
Well, it is still a one-to-one correspondence. You could as well introduce a vector space isomorphism
\varphi \, : \,V\otimes W \longrightarrow \mathbb{M}_{n\times m}(\mathbb{F})
and write the matrices as images under ##\varphi ## but I think it would only unnecessarily complicate notation. The difficulty is always the same: Did you transform the vectors or the bases? Does the object rotate or the coordinate system? If you want to be clear, you could also write the matrices as
\begin{pmatrix} a&b\\c&d \end{pmatrix}_{\mathcal{B}}
where you defined the basis ##\mathcal{B}## beforehand.
doktorglas said:
TL;DR Summary: Searching for a symbol to be used instead of "equals" between a tensor and a matrix.
Hi,
The ##g_{\mu\nu}## also does not represent the tensor, but the tensor components in some basis (see e.g. Wald's index-free notation). So I don't see the issue here.
I would argue that the whole point of the tensor index notation ##g_{\mu\nu}## is exactly the fact that we can write tensor equations without choosing any specific basis -- we only need the index structure of the constituent tensors. So, the symbol ##g_{\mu\nu}## is more of a placeholder for the components than the components themselves. Or did I misinterpret your reply?
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
