Symmetric Equation of Line in 3D converts to 2 Planes or 2 Lines?
In summary, the symmetric equation of a line in 3D is a representation of a line in 3-dimensional space using two parameters, typically denoted by <em>t</em> and <em>s</em>. It can be converted to 2 planes or 2 lines by setting one of the parameters equal to a constant value and solving for the remaining variables. The symmetric equation is equivalent to the Cartesian equation of a line in 3D and is used in various real-world applications such as engineering, physics, and computer graphics. However, it has limitations and may not work for lines that are parallel to the coordinate axes or may result in undefined equations.
Ocata
198
Hi,
An equation of the form Ax + By + C = 0 is a standard equation of a line in 2D.
An equation of the form Ax + By + Cz + D = 0 is an equation of a plane.
Is it possible to:
Describe a plane in space, written in standard form, such that one variable is missing from the equation?
For instance, if z = 0, then Ax + By + Cz + D = 0 becomes Ax+By+D=0.
If z = 0, then the equation of the plane can no longer describe a plane, but instead only describe a line, correct?
Reason for the question is because when a vector equation of a line described by two points, say (1,2,3) and (5,7,10), a vector equation in symmetric form can be written as such:
[tex]\frac{x-1}{4}= \frac{y-2}{5} = \frac{z-3}{7}[/tex]
which simplifies to two equations which seem to describe two lines instead of two planes:
[itex]\frac{x-1}{4}= \frac{y-2}{5} = \frac{z-3}{7} [/itex]
[itex]\frac{x-1}{4} =\frac{y-2}{5}[/itex] and [itex]\frac{y-2}{5}= \frac{z-3}{7}[/itex][itex]-5 \big(x-1)+4 \big(y-2) = 0[/itex] and [itex]7 \big(y-2) -5 \big(z-3) =0[/itex]
[itex]-5x + 4y - 3 = 0[/itex] and [itex]7y-5z+1 = 0[/itex]
As can be seen, these are two equations of two variables. I understand this to describe two lines. One line in the xy plane and another line in the yz plane. It doesn't make sense to me that two lines intersect to make a new line. So how is it that these two seemingly linear equations are actually two equations of planes? Is it possible that I just don't understand the equation of a plane well enough?
Guess #1: would be that these two equations are in fact linear equations, represent 2 lines instead of 2 planes, and I am calculating wrong to arrive a such equations.
Guess #2: would be that these two equations are actually equations of planes and due to 3 variables being utilized across 2 equations (even if each equation only contains 2 variables) some how represents two planes.
Ocata said:
Hi,
Is it possible to:
No. If a variable is missing, that just means the plane is parallel to the axis of the missing variable.
Yes, it is possible you need to study it a bit more. When you take any pair of the symmetric equalities they represent two planes and a point (x,y,z) is on both only if it is on their line of intersection. So the pair of equations, which are themselves representing planes, together represent their line of intersection.
Related to Symmetric Equation of Line in 3D converts to 2 Planes or 2 Lines?
1. What is the symmetric equation of a line in 3D?
The symmetric equation of a line in 3D is a representation of a line in 3-dimensional space using two parameters, typically denoted by t and s. It is written in the form x = x0 + at, y = y0 + bt, and z = z0 + ct, where x0, y0, and z0 are the coordinates of a point on the line, and a, b, and c are the direction numbers of the line.
2. How can the symmetric equation of a line in 3D be converted to 2 planes or 2 lines?
The symmetric equation of a line in 3D can be converted to 2 planes or 2 lines by setting one of the parameters, t or s, equal to a constant value, and then solving for the remaining variables. This will result in equations for 2 planes or 2 lines that intersect at the point (x0, y0, z0).
3. What is the relationship between the symmetric equation of a line in 3D and the Cartesian equation of a line in 3D?
The symmetric equation of a line in 3D and the Cartesian equation of a line in 3D are equivalent representations of the same line. The symmetric equation is written in terms of parameters, while the Cartesian equation is written in terms of variables. They can be converted to each other by solving for the parameters in terms of the variables, or vice versa.
4. Are there any limitations to using the symmetric equation of a line in 3D to convert to 2 planes or 2 lines?
Yes, there are limitations to using the symmetric equation of a line in 3D to convert to 2 planes or 2 lines. This method only works for lines that are not parallel to any of the coordinate axes. Additionally, it may result in equations for planes or lines that are not defined for certain values of the parameters, such as when the denominator of a fraction is equal to zero.
5. How is the symmetric equation of a line in 3D used in real-world applications?
The symmetric equation of a line in 3D is used in various fields such as engineering, physics, and computer graphics. It is used to represent the trajectory of moving objects, such as projectiles or particles, and to calculate their position at a given time. It is also used in computer graphics to create 3-dimensional models and animations.
