MHB Symmetrical Group: Prove Properties & Find Element Count
  • Thread starter Thread starter qamaz
    Group
The discussion focuses on proving properties of the symmetric group S_n, specifically regarding the sign of permutations and subgroup characteristics. It establishes that the sign of a permutation π, denoted sgn(π), is equal to (-1) raised to the power of n minus the number of disjoint cycles z. Additionally, it confirms that the subset A_n, consisting of even permutations, forms a subgroup of S_n. The relationship between the lengths of even and odd cycles is explored, highlighting how they influence the parity of n and the sign of the permutation. The thread emphasizes the importance of cycle structure in determining permutation properties within symmetric groups.
qamaz
$$\text{ Let } n∈ \mathbb{N} \text{ and } S_{n} \text{ symmetrical group on } \underline n\underline .
\text{ Let }
π ∈ S_{n} \text{ and z } \text{ the number of disjunctive Cycles of π. Here will be counted 1 - Cycle }. (a) \text{ Prove that } sgn (π) = (-1)^{n-z}.
(b) \text{ Prove that subset } A_{n}= \{π∈Sn∣sgn(π)=1\} ⊆ S_{n}\text{ is subgroup of } S_{n}.
(c)
\text{ Find number of elements } |A_{n}| \text{ of a subgroup } A_{n} \text{ from (b) }
I’ll just do part (a); the rest I leave to you. Note a few things to start with:
  • Even cycles (cycles of even length) are odd permutations whereas odd cycles (cycles of odd length) are even permutations.
  • Let $l_e$ be the sum of the lengths of the even cycles, and similarly $l_o$ for the odd cycles; let $z_e$ and $z_o$ be the number of even and of odd cycles respectively. Thus $n=l_e+l_o$ and $z=z_e+z_o$. Then note that $l_e$ is always even; on the other hand $l_o$ has the same sign as $z_o$. (If there is an even number of odd cycles, the sum of their lengths is even; if there is an odd number of odd cycles, the sum of their lengths is odd.) Also, the fact that $l_e$ is always even and $n=l_e+l_o$ implies that $n$ and $l_o$ have the same parity (both odd or both even).
  • $\mathrm{sgn}(\pi)$ depends only on $z_e$ and $\mathrm{sgn}(\pi)=\mathrm{sgn}(z_e)$. In other words, $\pi$ is an even permutation if there is an even number of even cycles and it’s an odd permutation if there is an odd number of even cycles. (Make sense? See observation (i) above.)
First, suppose that $n$ is even. Then $l_o$ is even and so $z_o$ is even (observation (ii) above). Hence
$$\mathrm{sgn}(n-z)=\mathrm{sgn}(z)=\mathrm{sgn}(z_e+z_o)=\mathrm{sgn}(z_e)=\mathrm{sgn}(\pi)$$
by observation (iii) above.
Now suppose $n$ is odd. Then $l_o$ is odd and so $z_o$ is odd (observation (ii)) and so $l_o-z_o$ is even. Then
$$\begin{array}{rcl}\mathrm{sgn}(n-z) &=& \mathrm{sgn}([l_e+l_o]-[z_e+z_o]) \\ {} &=& \mathrm{sgn}(z_e)\ \text{(since }l_e\ \text{and}\ l_o-z_o\ \text{are both even)} \\ {} &=& \mathrm{sgn}(\pi)\end{array}$$
again. QED.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
