Symmetrical parallel inductors, different currents? State Preparation
In summary: The system is fourth order because it includes the DC offsets. However, if you don't care about the DC offsets, you can simply treat the inductors as a single impedance. This will result in equal dynamics with DC offsets.This is because the state change (current) of each inductor is fully determined by the applied voltage, which is equally shared amongst them.I should have mentioned that I only extracted the problem statement (in English!) and the formulas from the video.
yucheng
232
57
JEE Pathfinder
https://youtu.be/a7wi7F_amJw
See below
N/A
We have there parallel inductors (i.e. having the same voltage) with the same inductance, having different currents at a particular time.
It appears that this is only possible if the current phasors have different phases
See bottom left of video below, ##I_1, I_2, I_3## (time already set to 10:18)
However, how is this 'state' 'prepared'? By symmetry, if we start by connecting a charged capacitor to the open-circuited parallel inductors, shouldn't the current phasors be the same?
Thanks in advance!
yucheng said:
We have there [sic] parallel inductors (i.e. having the same voltage) with the same inductance, having different currents at a particular time.
I didn't watch the video, but it would seem to me that you can only have different currents in the 3 inductors if they are connected one at a time to the capacitor. The 2nd and 3rd inductors connected will have smaller currents in them compared to the first one connected.
Just as well it's not in english. This is a mini-study in how to make people not reply to your post.
Likes berkeman
Trickery!!
  • Haha
Likes yucheng
Nope, I didn't watch your video either (OK about 15 seconds of it).
Note to others: this is a transient response problem where the inductors start with different ICs. Which would have been nice to know from the beginning.
I don't have time to answer yet. Except to say that the state of each inductor is fully determined by its current. So for a rigorous treatment of transient response this is a 4th order system. But an intelligent approach using superposition can simplify the dynamic response to a 2nd order system. The inductors can still be modelled as a single impedance if you don't care about how they share the DC current. Then you can separately solve for the different inductors, which should be equal dynamics with DC offsets. This is because the state change (current) of each inductor is fully determined by the applied voltage, which is equally shared amongst them.
Likes hutchphd
BTW, I'm not a fan of "phasors" for transient response problems. It's not wrong, but when you get to this level of complexity, you will do better to think in real math terms. For example, "phasors" contain no information about the DC offsets in a problem like this. Their existence depends on the steady state assumption that there is a single oscillation frequency and nothing else matters.
Anyway, yes, the "phasors" are the same, but the currents aren't.
Likes yucheng
I don't know either, to be honest!
@DaveE Do you mean DC offsets in the context of analog circuits?
I guess the right way to approach this problem is by setting up the differential equations and with the stated initial conditions right?
By the way, why is the system of fourth order though? Is there a way to see it immediately? Let me write down the differential equation first...
FAQ: Symmetrical parallel inductors, different currents? State Preparation
What are symmetrical parallel inductors?
Symmetrical parallel inductors are inductors that are connected in parallel and have identical inductance values. This configuration is often used to achieve a desired total inductance while distributing the current load evenly among the inductors.
How do different currents affect symmetrical parallel inductors?
In symmetrical parallel inductors, the total current is divided equally among the inductors if they are truly identical. However, if there are slight differences in inductance or other factors such as resistance, the currents may differ slightly. The overall inductance of the parallel combination will still be lower than the individual inductances.
What is the formula for calculating the total inductance of symmetrical parallel inductors?
The formula for calculating the total inductance (L_total) of symmetrical parallel inductors is given by the reciprocal of the sum of the reciprocals of the individual inductances (L). For two identical inductors, it simplifies to L_total = L/2. For n identical inductors, it is L_total = L/n.
How is state preparation relevant to symmetrical parallel inductors with different currents?
State preparation in the context of symmetrical parallel inductors with different currents involves setting up initial conditions and ensuring that the inductors are properly balanced. This may include ensuring that the inductors are identical, minimizing resistance differences, and carefully managing initial current distribution to achieve the desired performance.
What are the practical applications of symmetrical parallel inductors with different currents?
Symmetrical parallel inductors with different currents are used in various applications such as power distribution networks, RF circuits, and signal processing. They help in achieving desired inductance values, improving current handling capacity, and enhancing the overall performance of electronic circuits by balancing the load and minimizing losses.
