Symmetries in quantum mechanics and the change of operators
In summary: That's the same as ##\hat{V}##, except that the value of ##V## has been shifted by ##a##. So we have:##\tau^\dagger(a) \hat{V} \tau(a) = \hat{V} + a##which is the same as:##\hat{V} \tau(a) = \tau(a) (\hat{V} + a)##or, in more familiar notation:##\hat{V} |x+a\rangle = (V(x) + a) |x+a\rangle##which is the same as##\hat{V} |x\rangle + a |x\rangle = (V(x) +
Lebnm
31
When we make a symmetrie transformation in a quantum system, the state ##|\psi \rangle## change to ## |\psi' \rangle = U|\psi \rangle##, where ##U## is a unitary or antiunitary operator, and the operator ##A## change to ##A'##. If we require that the expections values of operators don't change, we have $$\langle \psi '| A' | \psi ' \rangle= \langle \psi | U^{\dagger}A'U | \psi \rangle =\langle \psi | A | \psi \rangle,$$ what suggest that ##A' = UAU^{\dagger}##. However, in some textbooks, like Sakurai, the change in the operator is ##A' = U^{\dagger}AU##. Why this difference appear? They are equivalent?
Check to make sure of the definition of ##U##. Are they saying ##|\psi'\rangle = U |\psi\rangle## or ##|\psi\rangle = U |\psi'\rangle##?
In the first case, ##A' = U A U^\dagger##, in the second case, ##A' = U^\dagger A U##
Thanks for answering. I think it's the first case. In section 4.3, Sakurai talk about discrete symmetries. The first example is the lattice translation; he considerer a periodic potential ##V## and define the translation operator ##\tau## such that ##\tau (l) |x \rangle = |x + l \rangle ## (##| x \rangle## is a eigenstate of the position operator). So he write $$\tau ^{\dagger}(a) V(x) \tau (a) = V(x + a).$$ But shouldn't it be: ##\tau(a) V(x) \tau ^{\dagger}(a) = V(x + a)##?
I think it's confusing to mix up the operator ##\hat{V}## with its value ##V(x)##, which is just a number. So here's the way I would say it:
##\hat{V}## is an operator which acts on position eigenstates as follows:
##\hat{V} |x\rangle = V(x) |x\rangle##
The ##V(x)## on the right side of the equals is just a number, not an operator, so acting on it with ##\tau(a)## or ##\tau^\dagger(a)## would do nothing. Similarly,
##\hat{V} |x+a\rangle = V(x+a) |x+a\rangle##
which is equivalent to:
##\hat{V} \tau(a) |x\rangle = V(x+a) \tau(a) |x\rangle##
Now, act on both sides with ##\tau^\dagger(a)##:
##\tau^\dagger(a) \hat{V} \tau(a) |x\rangle = \tau^\dagger(a) V(x+a) \tau(a) |x\rangle##
But remember, on the right-hand side, ##V(x+a)## is just a number, not an operator. So ##\tau^\dagger(a)## commutes with it, to give:
##\tau^\dagger(a) V(x+a) \tau(a) |x\rangle = V(x+a) \tau^\dagger(a) \tau(a) |x\rangle = V(x) |x\rangle## (since ##\tau^\dagger(a) = (\tau(a))^{-1}##).
So we have:
##\tau^\dagger(a) \hat{V} \tau(a) |x\rangle = V(x+a) |x\rangle##
So ##\tau^\dagger(a) \hat{V} \tau(a)## is the operator which acts on ##|x\rangle## and returns ##V(x+a) |x\rangle##
Likes Avodyne and Lebnm
FAQ: Symmetries in quantum mechanics and the change of operators
What is the concept of symmetry in quantum mechanics?
Symmetry in quantum mechanics refers to the invariance of a physical system under some transformation. This means that the system remains unchanged even if certain parameters, such as position or momentum, are altered. Symmetry plays a crucial role in understanding the behavior of quantum systems and is closely related to the conservation laws of energy, momentum, and angular momentum.
How do symmetries affect operators in quantum mechanics?
In quantum mechanics, operators are mathematical representations of physical observables, such as position, momentum, and energy. Symmetries can be expressed as transformations on these operators, which can lead to new operators that describe the same physical system. This allows for a deeper understanding of the underlying symmetries of a system and how they affect its properties.
What is the significance of symmetries in quantum mechanics?
Symmetries in quantum mechanics play a crucial role in determining the behavior and properties of physical systems. They can help identify conserved quantities, simplify calculations, and provide insight into the fundamental laws of nature. In addition, symmetries can also be used to classify different quantum systems and understand their symmetries.
Can symmetries be broken in quantum mechanics?
Yes, symmetries can be broken in quantum mechanics. This occurs when a physical system does not exhibit the same symmetry as its underlying laws. For example, in certain phase transitions, the symmetry of a system can be broken, resulting in a change in its behavior. The study of broken symmetries is important in understanding the behavior of complex quantum systems.
How do symmetries relate to the uncertainty principle in quantum mechanics?
The uncertainty principle in quantum mechanics states that it is impossible to know the exact values of certain pairs of physical observables, such as position and momentum, simultaneously. Symmetries can help determine the allowed values of these observables and how they relate to each other. In some cases, symmetries can also lead to restrictions on the precision of measurements, further illustrating the connection between symmetries and the uncertainty principle.
