Symmetry, absorbtion and benzene
In summary, symmetry is a concept used in science and mathematics to describe balanced arrangements of parts in objects or systems. Absorption is the process by which molecules or particles take up other substances, often used in chemistry to identify and quantify substances through their absorption of light energy. Benzene is a colorless, flammable liquid that is highly important in organic chemistry as a building block for a variety of compounds. Its high symmetry contributes to its stability and unique properties.
evidenso
37
Hey
Is it right that high symmetry molecules does not absorb light as good as low symmetry molecules? let's take an example like benzene versus benzene+hydroxyl?
Chemistry news on Phys.org
Depends on which atom or functional group you're are referring to ; if it's the same functional group I would imagine that a symmetric attachment would be less of an influence with an electric dipole .
Thank you for your question. The relationship between symmetry and light absorption is a complex one and cannot be generalized for all molecules. While it is generally true that molecules with higher symmetry tend to have lower absorption, there are exceptions to this rule. For example, benzene, which has a high degree of symmetry, is known to have strong absorption in the ultraviolet region due to its delocalized pi-electron system. On the other hand, molecules with lower symmetry, such as benzene+hydroxyl, may have weaker absorption because the presence of the hydroxyl group can disrupt the delocalization of electrons.
Furthermore, the absorption of a molecule also depends on factors such as the energy of the incident light, molecular structure, and electronic transitions. Therefore, it is not accurate to say that high symmetry molecules always have lower absorption than low symmetry molecules.
In conclusion, while symmetry can play a role in the light absorption of a molecule, it is not the only determining factor. Further investigation and analysis would be needed to fully understand the relationship between symmetry and light absorption in different molecules.
Related to Symmetry, absorbtion and benzene
What is symmetry?
Symmetry is a concept used in science and mathematics to describe objects or systems that have a balanced arrangement of parts. In chemistry, symmetry can refer to the spatial arrangement of atoms in a molecule, which can have important implications for its properties and reactivity.
How does absorption work?
Absorption is the process by which molecules or particles take up or assimilate other substances. In chemistry, it typically refers to the ability of a substance to absorb light energy, causing a change in its electronic state. This can be used to identify and quantify substances in a sample, as different substances absorb light at different wavelengths.
What is benzene?
Benzene is a colorless, flammable liquid that is a fundamental component of many organic compounds. It is a highly aromatic compound, meaning it contains a ring of six carbon atoms with alternating single and double bonds. Benzene is used in the production of a wide range of materials, including plastics, dyes, and pharmaceuticals.
How is symmetry related to benzene?
Benzene is an example of a highly symmetrical molecule, with all of its carbon-carbon bonds being identical in length and strength. This symmetry contributes to its stability and unique properties, making it an important building block in organic chemistry.
Why is benzene important in organic chemistry?
Benzene is important in organic chemistry because it is a versatile building block for creating other compounds. Its unique structure and properties make it a valuable starting material for synthesizing a wide range of substances, from pharmaceuticals to plastics to agricultural chemicals.
