Symmetry Breaking and the Metric
In summary, symmetry breaking refers to the phenomenon in physics where a system that exhibits symmetric properties at a high energy level will have those properties broken at a lower energy level. This concept is crucial in understanding the behavior and structure of particles in the universe. The metric, on the other hand, is a mathematical tool used to measure distances and define the geometry of a space. In physics, the metric is often used to describe the curvature of space-time in Einstein's theory of general relativity. Together, symmetry breaking and the metric help us understand the fundamental laws of the universe and how they shape the world around us.
Digs
Hello,
im a first year phd student, and I am reading http://arxiv.org/abs/0901.1847 right now in an attempt to figure out something cool to do with lie 3 algebras.
In the paper they mention that turning on a B field in the 1,2 dimensions breaks the SO(4) symmetry the theory has to SO(2)xSO(2), and as well the metric becomes diagonal, with some funny entries I don't recognize.
Why does the metric become diagonal? Also, why does the symmetry break to that?
THanks!
I ain't no expert, but I think what they mean is that a diagonal form like that is allowed (as opposed to: the most general expression you can have). So with the residual symmetry group it's always possible to obtain such an expression for the metric.
Think of it as normal GR. In that case it's always possible to (locally) obtain the Minkowski metric.
That would be my best guess.
Hello first year PhD student,
Thank you for sharing your thoughts and questions about the paper you are reading. It sounds like you are interested in exploring the concept of symmetry breaking and its relationship to the metric in a lie 3 algebra setting. This is a fascinating topic and I am happy to discuss it with you.
To start, let's define what symmetry breaking is. In physics, symmetry is a fundamental concept that describes the invariance of a system under certain transformations. In other words, a system is symmetric if it remains unchanged when certain operations are performed on it. However, in some cases, the symmetry of a system can be broken, meaning that the system is no longer invariant under those transformations.
In the paper you mentioned, the authors discuss how turning on a B field in the 1,2 dimensions breaks the SO(4) symmetry of the theory to SO(2)xSO(2). This means that the system is no longer symmetric under rotations in all four dimensions, but only under rotations in two dimensions. This breaking of symmetry is due to the presence of the B field, which introduces an external influence on the system.
Now, let's talk about the metric. In simple terms, the metric is a mathematical tool that describes the distance between points in a space. In this case, the metric refers to the spacetime metric, which is used to describe the geometry of spacetime. When the SO(4) symmetry is broken to SO(2)xSO(2), the metric also changes. This is because the symmetry of a system is closely related to its geometry. In this case, the symmetry breaking leads to a change in the geometry of spacetime, resulting in a diagonal metric with some unfamiliar entries.
I hope this helps to answer your questions. Keep exploring and asking questions, as this is an important step in your research journey. Best of luck with your studies!
Related to Symmetry Breaking and the Metric
1. What is symmetry breaking?
Symmetry breaking is a phenomenon in physics where a system that exhibits symmetrical properties at a higher energy level becomes asymmetrical at a lower energy level. This can happen through the spontaneous breaking of a symmetry or through an external force.
2. How does symmetry breaking relate to the metric?
The metric in physics refers to the measurement of distance and time in a given space. In the context of symmetry breaking, the metric can be used to describe the change in symmetry as a system transitions from a higher energy state to a lower energy state. This change in symmetry can be quantified by changes in the metric.
3. Can symmetry breaking occur in both classical and quantum systems?
Yes, symmetry breaking can occur in both classical and quantum systems. In classical systems, symmetry breaking can happen through a phase transition where the system changes from a symmetric to an asymmetric state. In quantum systems, symmetry breaking can happen through the spontaneous breaking of a symmetry, which is a common occurrence in particle physics.
4. What are some examples of symmetry breaking in nature?
One of the most well-known examples of symmetry breaking in nature is the Higgs mechanism, which explains the origin of mass in elementary particles. Another example is the breaking of rotational symmetry in ferromagnetic materials, where the spins of individual atoms align in a particular direction at low temperatures.
5. What are the implications of symmetry breaking in physics?
Symmetry breaking has significant implications in various fields of physics. In particle physics, it can help explain the properties of elementary particles and the origin of mass. In condensed matter physics, it can lead to the emergence of new phases of matter. It also plays a crucial role in cosmology, as it can explain the formation of large-scale structures in the universe.
  • Beyond the Standard Models
12K
