Symmetry breaking domain walls
In summary, topological defects in systems that exhibit a spontaneously broken symmetry can be localized or stretch out in one or more directions. They can be understood using topological arguments of the corresponding symmetrygroup. They are stable due to the fact that the defect arises due to a topological inequivalence between the state with a topological defect, and the state without one.
JustinLevy
895
Symmetry breaking "domain walls"
The only "spontaneously broken symmetry" that I can easily visualize, is cooling down a ferromagnetic material and having the spins randomly choose a direction to align. Since the choice is random, different regions will usually choose different directions, creating domains.
In theories where the vacuum spontaneously breaks a symmetry, are there also "domain walls" that form during non-equilibrium process of the symmetry breaking? What would these domains appear like, and can the theory be used to describe their evolution (or not really, since it wouldn't fit with our pertabative mathematical tools)?
Basically, any system which exhibits a spontaneously broken symmetry, which can be a gauge symmetry or some other type, has some way of allowing mismatches in its lowest energy, perfectly symmetric configurations. These mismatches carry some energy as they break the "optimal symmetry alignment".
So yes, there is a very richt study behind this. Such objects, which are formed due to a mismatch in the symmetry of the underlying degrees of freedom, are called topological defects. These defects can be localized (point-like or solitons) or stretch out in one or more directions (domain walls). They are called topological, because they can be classified using topological arguments of the corresponding symmetrygroup. This is also a way of understanding their stability: the defect arises due to a topological inequivalence between the state with a topological defect, and the state without one. On the other hand, it is possible for two defects to annihilate with each other, as they can "cancel each other out".
A famous example is the 't Hooft-Polyakov monopole, which predicts the existence of localized, monopole configurations in Yang-Mills theories. There are also the flux tubes you find in type II superconductors, which can be understood as vortices in the superconducting phase of the Cooper pairs. Another is the cosmic string -- yet to be discovered, and not to be confused with the strings in string theory --, which is the cosmic analog of the flux tube you find in superconductors. Such objects are believed to be formed during the cooldown after or during the inflational period of the early universe. Last but not least, there are also the vortices in the Bose-Einstein condensates, and the vortices in the quantum Hall effect.
Hello JustinLevy,
As far as I concerned, I will just discuss phi^4 in broken phase. The answer is yes, there are domain walls (e.g. in the well-known d=4 for theory too).
When doing QFT for example using the effective potenial, the the non-perturbative aspects you expect are actually hidden in the flatness of the potential between the would-be minima of the tree-level potential (That's Maxwell construction).
An interesting point is that due to this non-perturbative effect, the perturbation theory fails to describe the inner region. It can be seen easily that the loop expansion is lost in this region due to the competiotn of two homogenous saddle points -signaling the presence of only one that is inhomogenous- and you obtain an imaginary part of the potential that may be interpreted as decay rate from the false vacuuim (phi=0) to the genuine one (phi=v).
Now turning to High Energy physics, you could wonder if the Higgs mechanism is actually perturbative. Indeed, you build the fluctuation to generate the mass of let's say fermions in the external region (phi>v) that should be perturbative (not seeing the competition in the internal region). But one the other hand the minimum lies at the exact location of the frontier between the two regions (the domain wall in question) so that you could feel non-perturbative fluctuations coming form the internal region as well.
So that this question that has been adressed decades ago has no clear answer as far as I know. We just hope that perturbation theory is valid on the external part of the broken potential... Let me mention that lattice proof of renormabizability of phi^4 in broken phase done by Luscher and Weisz had to ASSUME there was a perturbative relation between vertex function computed in 0 and the ones computed at the minimum...
Related to Symmetry breaking domain walls
What is symmetry breaking in the context of domain walls?
Symmetry breaking refers to the phenomenon in which a system with a symmetric ground state undergoes a transition to a lower energy state with less symmetry. In the context of domain walls, this refers to the formation of domains with different orientations of their magnetic moments, breaking the symmetry of the material's magnetic properties.
What causes symmetry breaking in domain walls?
Symmetry breaking in domain walls is caused by the competition between different energy states within the material. This can be due to interactions between the magnetic moments of atoms, external magnetic fields, or thermal fluctuations. The resulting domain structure is determined by the balance between these competing energies.
What are the different types of symmetry breaking in domain walls?
There are two main types of symmetry breaking in domain walls: discrete and continuous. Discrete symmetry breaking occurs when the domain structure has a finite number of possible states, such as in ferromagnetic materials. Continuous symmetry breaking, on the other hand, occurs when the domain structure has an infinite number of possible states, such as in antiferromagnetic materials.
How do symmetry breaking domain walls affect the properties of a material?
The presence of symmetry breaking domain walls can significantly affect the properties of a material. For example, they can lead to changes in the magnetic, electrical, and thermal properties of the material. They can also affect the material's response to external stimuli, such as magnetic fields or temperature changes.
Can symmetry breaking domain walls be controlled or manipulated?
Yes, symmetry breaking domain walls can be controlled and manipulated through various techniques such as applying external magnetic fields, inducing strain or stress, or using spin-polarized currents. This allows for potential applications in spintronics, data storage, and magnetic sensors.
