Symmetry in Higher Dimensions: Sean Carroll's Video & Physics
In summary, Sean Carroll discusses 120 degree rotations and flipping of triangles as symmetries in his video on symmetry. He also mentions the concept of higher dimensional symmetries, which are physically impossible in 4D spacetime but may have mathematical solutions. While there have been attempts to incorporate these symmetries into physics, they have not been successful and are considered to be dead-ends. However, discrete symmetries such as reflections and time-reversal are still of interest in physics.
Shirish
244
32
I'm watching Sean Carroll's video on symmetry [relevant section at around 8:05]
He talks about 120 degree rotations of triangles that leave them invariant. Then he proceeds to talk about flipping them with an interesting (at least to me) remark - "there's nothing that says I'm confined to moving (the triangle) in the plane".
A natural scenario that comes to mind following this is: if there was an observer that's purely confined to the 2D plane, and if there were a triangle on that plane, then the observer could completely specify and map out the triangle by roaming around it and measuring its lengths and angles.
Also, for that observer, the notion of 120 degree rotations would be a totally natural symmetry
to think about. On the other hand, a flip would be a not-so-natural, "higher dimensional" symmetry that's not confined to the 2D plane.
I'm currently studying special relativity and in that context we usually talk about homogeneity (translational symmetry) and isotropy (rotational symmetry) as far as I know, which are symmetries in our usual 4D spacetime. So I'm curious as to whether there are "higher dimensional" symmetries in our case as well. I'm sure fields like group theory address such questions, but I'm curious about how prevalent/useful this "higher dimensional" symmetry (there's probably a proper technical term for this which I don't know, hence the quotes) idea is in Physics.
Are there any fields (in Physics) where the notion of such kind of symmetries is useful?
Likes etotheipi
To me his 'flip' operation looks like it can be completely defined in 2D. E.g. if we orient a coordinate system so that the ##y## axis lies along the direction of the mirror line, and the ##x## axis is perpendicular to the mirror line, then the symmetry operation is ##T(x) = -x##. The mini-observers in the plane drop a perpendicular to the mirror line and shift all of the points along the direction of those perpendiculars to an equal distance on the other side of the mirror line.
(Though in 3D, a reflection in the mirror plane in 3D is generally not the same as a rotation of 180 degrees. Although if we embedded his (2D) triangle in the 3D space and performed these two 3D operations (w/ the mirror plane ##\bot## the triangle), they would in this case have the same effect).
But that is all that I can tell here, I am interested to see what others have to say!
Likes vanhees71
Many very intelligent people have tried for 100+ years to construct useful models of physics based on higher dimensional spacetimes, i.e., higher than the usual 4D.
Afaik, all such efforts turned out to be dead ends, at least as far as physics is concerned.
You can define it mathematically without making use of a third dimension. But you could not actually perform it in 2D with 2D objects made of 2D "atoms" that cannot interpenetrate each other, because you could not do this:
In three dimensions, you can implement this operation because there is now "room" for the atoms to slide past each other; but in true 2D there is no "room" to do this. Or, to put it another way, in true 2D the ordering of atoms along any line cannot be changed, and the "parity" operation you describe requires the ordering of atoms along lines to be changed.
Likes vanhees71 and etotheipi
@PeterDonis , @etotheipi : Good point - even though a "reflection" and "flip" have the same end result as you guys pointed out, one is physically impossible and the other isn't. So after your feedback, by "higher dimension" symmetries I now mean those that are physically not possible in 4D spacetime, even though they're mathematically possible.
Pretty sure group theory (or some other field's mathematicians) folks must have come up with several symmetries like that. To explain those physically, one might need to invoke an assumption that 4D spacetime is embedded in higher dimensional space (just like that 2D observer might do for a "reflection").
I'm pretty sure this is extremely speculative and possibly untestable, but since I'm a noob, I was curious whether physicists have considered this question, formulated hypotheses around it and come up with possible predictions. From what @strangerep said, any work around this question has lead to dead-ends.
As noted, "flipping" a triangle is equivalent to a reflection, and such discrete symmetries are of interest. Physics is invariant under time-reversal, for example. Most of physics is symmetric under "parity", a spatial reflection, but anything chiral (notably the weak force) or involving rotation can be anti-symmetric. Higher dimensions are not involved.
The simplest higher dimensional theory I'm aware of is Kaluza-Klein theory, which is a 5d extension to GR. Somewhat surprisingly, electromagnetism drops out of it alongside gravity. Unfortunately so does a scalar field, a "fifth force" that is not seen in nature, so it remains mainly a curiosity. I think similar reasoning led to string theory, which is still an area of active research.
Likes etotheipi
Interestingly physics is NOT invariant under these discrete transformations. The weak interaction violates each separately (as seen one by one in experiments). Only CPT (the "grand reflexion", i.e., the combination of charge conjugation, space reflection, and time reversal) still is not seen to be violated, strengthening the belief that there's a lot of truth in local relativistic QFTs.
Likes Ibix and etotheipi
This depends on what "higher dimensional" means. If I choose (because I want to :smile:) to interpret the extra dimensions as belonging to an internal non-spacetime space, then we have the symmetry group ##G \times P##, where ##G## is the the symmetry group of the internal space, and ##P## is the Poincaré group, the symmetry group of a fine (pin intended) space, Minkowski spacetime. In the standard model, ##G = SU\left(3\right) \times SU\left(2\right) \times U\left(1\right)## (quantum chromodynamics and electroweak). Physicists have tried other groups for ##G##, e.g., GUTs based on ## SU\left(5\right)## (ruled out by experiment) and ## Spin\left(10\right)##, which physicists sometime call ## SO\left(10\right)## (because they have isomorphic Lie algebras).
Likes dextercioby
Related to Symmetry in Higher Dimensions: Sean Carroll's Video & Physics
1. What is symmetry in higher dimensions?
Symmetry in higher dimensions refers to the concept of objects or systems being unchanged or invariant under certain transformations in higher dimensions, such as rotations, translations, and reflections.
2. Why is symmetry important in physics?
Symmetry plays a crucial role in physics because it allows us to understand and describe the laws of nature. Many fundamental principles and equations in physics, such as conservation laws and the laws of motion, are based on the idea of symmetry.
3. How does Sean Carroll's video explain symmetry in higher dimensions?
Sean Carroll's video provides a visual representation of higher dimensions and how symmetry can be applied to understand the laws of physics. He uses the example of a cube in 3D space and how it can be rotated and reflected to maintain its symmetry, and then extends this concept to higher dimensions.
4. Can symmetry in higher dimensions be observed in the real world?
Yes, symmetry in higher dimensions can be observed in the real world through various physical phenomena. For example, the symmetry of a snowflake is a result of the underlying symmetries in the arrangement of its water molecules in higher dimensions.
5. How does understanding symmetry in higher dimensions contribute to our understanding of the universe?
Studying symmetry in higher dimensions allows us to better understand the fundamental laws of the universe and how they apply in different dimensions. It also helps us to develop new theories and models to explain complex phenomena, such as gravity and quantum mechanics, in a more unified way.
  • General Math
  • Beyond the Standard Models
  • Science Fiction and Fantasy Media
  • Quantum Interpretations and Foundations
  • Linear and Abstract Algebra
