Symmetry on the partition function
In summary, the conversation discusses the partition function and its relation to the pressure. It is mentioned that multiplying the partition function by a positive constant does not result in any conservation laws and is not considered a symmetry. This is because the transformation simply shifts the energy of each state without changing any observables. Noether's theorem is also mentioned in relation to the Hamiltonian and the partition function as a dynamical variable.
Mr rabbit
We have a partition function
## \displaystyle Z=\frac{1}{N! \: h^{f}} \int dq\: dp \:e^{-\beta H(q,p)} ##
And we obtain, for example, the pressure by ##\displaystyle p = \frac{1}{\beta} \frac{\partial\: \ln Z}{\partial V}##. So if we do the transformation ##Z \rightarrow a Z## where ##a >0## we obtain the same pressure. This is not a symmetry? It should exist a conserved quantity?
The transformation ##Z \rightarrow aZ## simply takes every Boltzmann factor and multiplies it by ##a##, which is equivalent to adding a constant amount of energy ##\frac{1}{\beta}ln(a)## to the energy of each state. Shifting every energy up or down consistently won't change any observables. There's no reason why that would result in any conservation laws. If you're referring to Noether's theorem, the Hamiltonian of the system isn't invariant and the partition function is a dynamical variable. Hope that helps!
Likes Mr rabbit
Thank you!
Related to Symmetry on the partition function
1. What is symmetry on the partition function?
Symmetry on the partition function refers to the property of a system where the partition function remains unchanged under certain transformations, such as translations or rotations. This symmetry is important in statistical mechanics as it allows for simplification of calculations and analysis of a system's behavior.
2. What is the significance of symmetry on the partition function?
The presence of symmetry on the partition function can provide insights into the physical properties of a system. It allows for the identification of conserved quantities and the determination of equilibrium conditions, which can aid in understanding the behavior of a system.
3. How is symmetry on the partition function related to entropy?
Symmetry on the partition function is closely related to the concept of entropy, which is a measure of the disorder or randomness in a system. The presence of symmetry can affect the number of microstates available to a system, and thus impact its entropy.
4. What are some examples of systems with symmetry on the partition function?
One example is the ideal gas, where the partition function remains unchanged under translations and rotations of the gas molecules. Another example is a crystal lattice, where the partition function is symmetric under lattice translations.
5. How is symmetry on the partition function used in practical applications?
Symmetry on the partition function is used in various applications, such as in the calculation of thermodynamic properties, phase transitions, and in the study of quantum systems. It also plays a crucial role in the development of models and theories in statistical mechanics and physics.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Quantum Physics
  • Quantum Physics
