Symmetry with respect to a circle
In summary, the conversation discusses a complex analysis problem involving points x and y that are symmetric with respect to a circle. The writer is trying to understand why the cross ratios of these points and three other points on the circle are equal to their complex conjugates. The writer is confused about how to choose the points a, b, and c in order to cancel certain terms in the ratios. They also question the use of the term "symmetry" in this context and suggest different ways x and y could be symmetric with respect to the circle.
mrbohn1
97
Could someone please just explain a step in a proof for me?
Suppose x and y are symmetric with respect to a circle, and a,b and c are three points on the circle. This means that:
(x,a,b,c) = ([tex]\bar{y}[/tex],[tex]\bar{a}[/tex],[tex]\bar{b}[/tex],[tex]\bar{c}[/tex])
The writer then says:
"symmetry only depends on the circle, and not on the points, so if x and y are symmetric then:
[tex]\frac{x-b}{a-b}[/tex] = [tex]\frac{\bar{y}-\bar{b}}{\bar{a}-\bar{b}}[/tex]"
I understand why this would be if the points were on a straight line, as then you could choose c to be the point at infinity, and the cross ratio would reduce to this. But why is it also true for a circle?
You need to give us some more information. Are we talking about a circle in the real plane? What's the significance of [tex]\bar{y}[/tex]? That suggests conjugates, so maybe we're not talking about circles in the real plane. And what does (x, a, b, c) denote?
Fair enough!
This is a complex analysis problem - the circle is in the complex plane.
If x, a, b, c are complex numbers, then (x,a,b,c) denotes the cross ratio:
[tex]\frac{(x-b)(a-c)}{(x-c)(a-b)}[/tex]
Two points x and y being symmetric with respect to a circle means that if a, b, c are any three points on that circle, then:
(x,a,b,c) = [tex]\overline{(y,a,b,c)}[/tex]
(ie. the cross ratio of x, a, b, c is equal to the complex conjugate of the cross ratio of y, a, b, c ).
So: [tex]\frac{(x-b)(a-c)}{(x-c)(a-b)}[/tex] = [tex]\frac{\overline{(y-b)}\overline{(a-c)}}{\overline{(y-c)}\overline{(a-b)}}[/tex]
But the text says that we can choose the points a, b, c such that some of these terms cancel and we get:
[tex]\frac{(x-b)}{(a-b)}[/tex] = [tex]\frac{\overline{(y-b)}}{\overline{(a-b)}}[/tex]
I don't understand this - as far as I can see this would only be possible by choosing c to be infinity, but the circle does not contain the poiint at infinity.
Is it considered bad form to post a reply to your own question to get it back to the top of the board?
I had one class on complex analysis in grad school, but I have to confess we didn't cover any of the ideas you've presented, such as symmetry wrt a circle or the cross-ratio business.
So looking at what you have and where you want to go, it seems that you want the a -c and x -c factors to cancel in the ratio on the left, and the a -c and y -c (conjugate) factors to cancel in the ratio on the right. For the one on the right, if you choose a = y those factors cancel, but on the left what seems to work is choosing a = x. You said that one could choose a, b, and c, but I don't think you can choose a to be simultaneously equal to both x and y, so that doesn't seem to help.
What bothers me is that the word "symmetry" is used in this problem, but I don't have a clear picture in mind of where x and y are located on the circle. I would think that x and y being symmetric with respect to the circle means one of the following:
  1. Re(x) = Re(y) (the points are directly across the real axis from one another so that x = conj(y))
  2. Im(x) = Im(y) (the points are directly across the imaginary axis from one another)
  3. Arg(x) = Arg(y) + k*pi, where k is an integer (symmetry about the origin)
Is symmetry with respect to a circle what I have described here?
Sorry I'm not able to provide more help.
FAQ: Symmetry with respect to a circle
What is symmetry with respect to a circle?
Symmetry with respect to a circle is a type of symmetry in which an object or shape can be rotated around a central point or axis and still appear the same. It is also known as circular symmetry.
How is symmetry with respect to a circle different from other types of symmetry?
Symmetry with respect to a circle is different from other types of symmetry, such as reflection or translation, because it involves rotation rather than mirroring or shifting. It is a more complex form of symmetry that can be seen in natural phenomena, such as flowers or snowflakes.
What are some examples of objects with symmetry with respect to a circle?
Examples of objects with symmetry with respect to a circle include wheels, clocks, and circular logos. Natural examples include sunflowers, spider webs, and the patterns on certain seashells.
How is symmetry with respect to a circle used in mathematics and science?
In mathematics and science, symmetry with respect to a circle is used to describe and analyze patterns and shapes. It is also used in the study of crystal structures and the behavior of waves.
Can an object have both symmetry with respect to a circle and other types of symmetry?
Yes, an object can have multiple forms of symmetry. For example, a square has both rotational symmetry and reflectional symmetry. However, an object can only have symmetry with respect to a circle if it has a circular or radial shape.
